Go Back  MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W204)
Mirror tilt when you go into reverse >
Old 06-30-2019, 11:36 AM
C250
Hi i have a c250 can anyone help how to make the mirror go down when you select reverse I have electric seats but they're not memory seats can anyone help cheers
Gary Ashenden is offline
Old 06-30-2019, 07:12 PM
MBpippo's Avatar
2013 W204 C250 Coupe
You need the Mirror Package (P49) for this. Look up your VIN to see if you have it - www.datamb.com
MBpippo is offline
Old 07-02-2019, 10:59 AM
CJG
CJG's Avatar
2016 C300 4MATIC
You also need to be sure the window selector on the driver's door is set to the passenger window. As if you were going to adjust the passenger side mirror.
CJG is offline
Old 07-11-2019, 02:58 PM
MB Marko's Avatar
2012 C300 4Matic Sport Sedan
I think theres more to it then just P49 my mirrors never move when I go in reverse, even if i have them selected like im adjusting them. I defiantly have P49 it sates it in my build sheet as P49 MIRRORS PACKAGE.
MB Marko is offline
Old 07-11-2019, 03:02 PM
MB Marko's Avatar
I found some who posted this in the W205 section so there is a way to set it up if you have never used it before, im guessing its the same method.
So basically when you get in the car look at the mirror selection light. If it's not on, or lighting the driver side, switch it to the passenger side. Next, put the car in reverse. If the mirror does not tilt, tilt it manually yourself to your comfort. Once you've manually adjusted the mirror, put the car into drive and drive over 5 mph and you'll see the mirror go back up to the original position. Try putting it in reverse, and it will tilt down to the position you set before. That's pretty much it and the right mirror light should stay lit everytime you start the car (unless you manually switch it to the left light). Sometimes if I don't want the mirror to tilt down (like reverse parking), then I select the left side and it won't tilt. Afterwards, if I want it to tilt, I just select the right light.
MB Marko is offline
Quick Reply: Mirror tilt when you go into reverse
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
