Wiper and washer fluid not working
This morning I turned on the wiper but no response. I pressed the washer fluid button but no response.
I drover the car to work anyway, the same stock switch works for high beam and turn signals. I'm hoping it's a fuse. Does anyone know the location and fuse number for the wiper and washer fluid? Any other suggestion is highly appreciated. I have a 2013 C250. |
There should be a map with fuse # and what it is for. I remember it is in the trunk where the emergency kit is kept in my 2011.
Originally Posted by C300CA
(Post 7801324)
Okay. When I get off work I will try to find in my fuse map which is for the wiper. Hope 2011 fuse is the same as your 2013.
I feel bad that I misplaced the fuse map, nowhere to be found at the moment. I used the map when I installed backup camera.
Before I go to dealer for a service, I always take everything out and put things back afterwards. Easy to lose things that way. I will keep looking. |
(Post 7801902)
Before I go to dealer for a service, I always take everything out and put things back afterwards. Easy to lose things that way. I will keep looking. I checked wiper, fluid reservoir motor and rain sensor fuse, #10 and #13 in the engine bay and they turned out ok. I also tested the reservoir connector for power and it shows 12 volts with car turned off and pressing the button. So, I'm not sure what could be the issue. If I knew for sure it's the steering column switch I would replace it but just don't wanna throw money at it. |
I found the map in my thick C-Class file pile.
Yes, it says fuse #10 and #13 are for Windshield wipers, front. However, #13 shows up multiple places either alone or with other fuses, very confusing to me: ABS/ASR/BAS/ESP, #1, 6, 13, 14, 16, 20, 21 Fanfare horn, #13, 31a, 31b Headlamp flasher, #13 Multi-function steering wheel, #13 Rear window washer system, #13, 38 Steering wheel adjustment, #13, 62 Switch illumination, #2, 3, 12, 13, 16, 17, 18, 26, 39, 41 Turn signal lamps, #2, 13, 41 Windshield washer pump, #13 Windshield wiper, rear, #13, 38 I am lost. |
Did you hear washer pump operating sound when you pushed the button, or nothing at all?
(Post 7802266)
I called the dealership and they charge $165.00 for diagnostic. I will go that route. If the wiper motor, fluid motor or the actual switch is bad, I will do the work myself. |
“car is off", is the key on first notch or or the key is out?
I just tried my car. when key is turned to first notch, pushing the switch will turn on the washer pump and windshield wipers. |
With the car off, on or key in the 1st notch, no sound from washer pump or no wiper movement.
I don't know if the wiper motor is bad does the automatically shuts off the pump or not. |
I assume you have also tried key on 2nd notch (on) as well as when you are driving?
(Post 7802557)
I'd think you can try this. With the reservoir connector unplugged, test the pins on the reservoir with meter set for resistance. When the washer switch is pushed, the resistance should be some thing other than open circuit.
I took the car to my indy European shop, it's not the fuse.
He needs more time, it could be the motor, relay, SAM. I will need to drop off the car for a day or two. |
Hi, I have exactly the same issues. Has this issue been resolved? Could you share what was the problem?
Originally Posted by ElenaDemos
(Post 8256747)
I replaced it myself., I would say if you have the right tools it was not that bad of a DIY job. Something like this https://cimg3.ibsrv.net/gimg/www.mbw...2b1b81f730.png |
Perfect, thanks a lot for the reply
(Post 8257543)
Check the bonnet
This happened to me. If the bonnet isn't closed properly the sensor will stop the wipers and fluid to save any damage.
Yes, if the hood is not properly latched the wiper or fluid wouldn't work.
Originally Posted by nayf1974
(Post 8824699)
With the bonnet open, I was reinstalling the wipers and couldn’t initially figure out why the wipers and fluid spray stopped working all of the sudden. Turns out the MB engineers were just thinking one step ahead! |
