Rear main seal leak
Old Jul 18, 2019 | 10:30 PM
pheagles's Avatar
C300, G500
Rear main seal leak
Have leak beginning on my 2011 c300 with 85,000 miles. Any recommendations for an oil additive? Dealer wants $1,700 to replace seal.
Old Jul 18, 2019 | 11:19 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
Rear main seal on a M272 engine at 85k miles??? That is hard to believe, at least for me. I have done tons of rear main seals on M112/M113 engines. You know most people confuse the oil leak from the centrifuge cover or the vacuum pump with a leak from the rear main seal. If I was you, I would get a second opinion.
Old Jul 21, 2019 | 04:57 PM
ezshift5's Avatar
Mercedes C250 Coupe
Actually, a tech has insight here (and he just may be right). Please keep us in the loop>
ez
Old Jul 27, 2019 | 10:47 PM
pheagles's Avatar
C300, G500
Thanks for your input. My MB dealer noted on my last oil change that there was a rear main leak. Put on my lift and it is wet but will have to remove cover to verify. Hopefully just the dealer trying to get $1,700.
Old Jul 28, 2019 | 11:07 AM
timlippold's Avatar
2008 C300 Sport
Had same misdiagnosis. Check the cam bore covers. These often leak and are an easy fix.
