Belt tensioner
Old Aug 18, 2019 | 01:16 PM
Runner06's Avatar
C250sport
Belt tensioner
2013 C250 96,000miles should i change out original belt tensioner? How can you tell if it is failing?
Old Aug 18, 2019 | 04:15 PM
Runner06's Avatar
C250sport
It currently is working, i was just wondering if i should be doing a preventive change out, to avoid a failure resulting in an expensive engine fail!
Old Aug 19, 2019 | 03:37 AM
azblk's Avatar
2013 C250 SPORT, 2014 WRX STI SEDAN, 2017 E300 4MATIC
You mean chain tensioner?
Old Aug 19, 2019 | 08:05 AM
gamma300C's Avatar
2009 MB C300 Sport 4matic
If the serpentine belt is like my C300 this article might help..note the section where it describes the markings that show if the tensioner is in spec. With the belt off you can usually tell if the pulley is worn/rough. Obvious noise on running with belt is usually evident but only when pulley bearing is really shot.
https://www.pelicanparts.com/techart...eplacement.htm
Old Aug 19, 2019 | 06:26 PM
Runner06's Avatar
C250sport
Makes sense thanks for your response!
i will pay attention to the belt wear and pulley noise
thanks
Old Aug 19, 2019 | 07:20 PM
Bobby204's Avatar
2001 R129 SL500, '08-'20 W204 C350
Dealer nagged me about replacing it (making a slight rattle noise) around 75k. Held off until belt is due and had them both done at the same time.
Old Aug 19, 2019 | 10:17 PM
timlippold's Avatar
2008 C300 Sport
I replaced mine at 100k miles as a precaution
Old Aug 20, 2019 | 10:47 AM
Moto_Guzzi's Avatar
2008 C350-Sport-AMG-Active Agility Pack(Not reliable) +Izuzu KB6 3L(It seems Reliable)+Mazda
Hi, in my case I just heard a slight noise from the front, my wife would not have noticed it. I decided to replace belt and 3 pulleys, 2 slave and one the tentioner.
After removing them I found thst the smallest pulley(C350) I could only hear noise next to my ear. I opened it up and it was dry(I would say the weak point here, not well manufactured). The larger slave pulley was perfect very good quality. The tentioner pully was good no bearing problems.
I however replaced all 3 with the belt while at it.
Old Aug 20, 2019 | 12:57 PM
Runner06's Avatar
C250sport
Thanks i will most likely replace at next service interval
98000 miles
appreciate the responses
