My DWS06 Rears are now cupped
Old Aug 22, 2019 | 03:40 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Yes, dont regard the OEM psi's with other wheels.
17's are stock and these are 19's
Old Aug 22, 2019 | 05:03 PM
superangrypenguin's Avatar
A car
Originally Posted by Adi-Benz
Will rebalancing my rear wheels help?
No. However, did you get the optional "alignment" kit installed on your 204?
I am shocked that your dealership told you all was fine on your W204 if not, because there's a lot of settings (I don't remember which: camber/caster) that cannot be adjusted because MB cheaped out on parts.
When I had my 204 my tire wear was always crap until I got that OEM kit installed which allowed the tech to adjust a lot more than what is factory. That fixed it for me.
Old Aug 22, 2019 | 05:28 PM
Adi-Benz's Avatar
Do you mean in regards to the 'camber bolts' they sometimes charge people for when doing alignment? Probably so
Old Aug 26, 2019 | 10:02 AM
A car
Sorry for the delay in my reply. Yeah, I did. I'd double check because that's probably the main factor in this issue. If you have it installed, then sorry, I have absolutely no idea what's going on here. My rears always wore 100% even despite me driving like a mad man.
Old Aug 26, 2019 | 10:34 PM
LogicalApex's Avatar
2014 C300 Luxury
I know you have mentioned you have had alignment and etc checked and I don't have staggered wheels (I have Luxury config). But my DWS06 wore evenly and I'm on my second set wearing perfectly no matter how I drive on them.
I have only done maybe 1 or 2 alignments in 80K miles of driving on the car.
Old Aug 27, 2019 | 02:19 PM
Adi-Benz's Avatar
Do you guys always keep your oem wheels when doing alignment? Those who only have OEM wheels should not answer this question.
My dealer said it's fine either way, stock wheels or aftermarket larger ones.
Old Aug 27, 2019 | 05:18 PM
  #32
ygmn's Avatar
2015 E400 Sedan
huh?
what do you mean?
Old Aug 27, 2019 | 10:30 PM
  #33
Adi-Benz's Avatar
I have aftermarket wheels that are wider and larger in diameter.
Anyways, that won't affect the alignment from what I understand, as the specs won't change regardless.
