Xenon turn signal module coding?
Old Dec 11, 2020 | 05:36 AM
Dj-rix's Avatar
C350
Since owning the car the front turn signal in the xenon headlight has never worked.
I believe the car had a bump on the same front corner prior to me owning the vehicle.
how can I check to see if the turn signal module is correct for my vehicle? I’m thinking that the headlight may have been replaced when the vehicle was repaired, but wrong turn signal module used or maybe not coded to the vehicle.
Old Mar 24, 2021 | 10:25 AM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
The dealer or someone with access to XENTRY can hook it up to your vehicle and diagnose the issue
