Trunk Fuse Box - identifying hot side
when using a fuse tap the orientation of the fusetap matters. Is there an identifier on the fusebox to know which side of the blade fuse would be “hot”
When you remove a fuse you can see a + and - look. Its a bit hard to get my multimeter probes in to be sure however.
Basically one side is the side getting power and the other side when a fuse is inserted carries the power to the component. Obviously if the fuse is already in outting probes to the top of the fuse will just show both sides with power.
I have a full most based sound system which i installed, Hk has been replaced with a BIT dmi, processors and an aftermarket amp. All operated as intended for over a year but with the recent addition of an apple car play unit into the command unit. I am now pulling constant power to my bit dmi which subsequently leaves my amps etc running. Essentially a drain and the culprit is highly likely the carplay module.
the fuse testing is to basically temporarily fit a fuse tap (want to be sure it goes in correctly and safely) so that i can run a test wire out from a few circuits, lock the car and work out powerdowns on the command related fuses e.g. rear cam, tv tuner, sound system amp. This will confirm that all those items in the most loop are getting constant power and not going off.
when carplay module is unplugged these items power down as intended. Its more for a fault find and to confirm suspicions but when using these taps i want to ensure they go in correctly and safely.
Thank you both
Thank you both
For others - It seems the hot side is the side with a (-), The (+) is not powered. When fitting a fuse tap ensure the orientation of the lead out to your accessory falls on the + side. This is based on an assumption of a few i tested in the rear Sam, It would be best to use a similar test to confirm the hot/cold side when using fuse taps
