2002 C240 Key-Cluster Issue
Old Jun 8, 2021 | 06:05 PM
MikeABCD1234's Avatar
2002 C240
Hello, I have a 2002 C240. I just replaced the batteries in my two keys. Now the cluster works fine with one key but doesn't work with the other. The keyless locks work fine with both. The car runs fine with both.
Any suggestions on how to get the cluster working with the other key?
thanks, Mike
Old Jun 8, 2021 | 10:23 PM
antiguangenius's Avatar
2008 S550 4Matic, 2007 GL450, 2008 C300, 2018 GLE63 AMG
your car is a W203
but what do you mean by the cluster doesn't work?/
MB cluster doesnt use immobilizer and if the SSID doesnt match cluster will still woke but the miles will be like this " ----- "
Old Jun 12, 2021 | 06:16 AM
2002 C240
W203 Key Issue
Hello, as mentioned, I have a 2002 W203. I replaced the batteries in my two keys. Now everything works fine with one key but not the other. The keyless locks work fine with both. The car runs fine with both.
as far as I can tell, the systems that don't work include: cluster (everything is blank, LED screen works but stays in parked mode displaying temp, time, mileage, gear shift position), lights, power windows, wipers, moon roof, etc.
Any suggestions on how to get the key functioning again?
thanks, Mike
Old Jun 12, 2021 | 10:16 PM
if both keys can START the car then everything should work
Old Jun 13, 2021 | 07:39 AM
2002 C240
Thanks for the responses antiguangenius. I completely agree, everything should work. Unfortunately, the car runs and drives but nothing else works with the second key.
Old Jun 13, 2021 | 09:08 PM
what you can do is check the actual data of none working parts with the key in question using the scan tool and see if drive authorization is wrong
