Oil filter housing gasket leaking
I am planning to tackle this soon and was wondering if anyone can give me some tips.
Can it be done by either removing the starter or the top air box?
Any suggestion?
Mine is supercharged M271 and I did mine from the top, I don't think it would be possible to do from underneath.
Order new inlet manifold to head gaskets I think that theses are 4 o ring style and then the oil filter housing to block and housing to oil cooler shaped o rings.
Mine did 125,000km and the starter completely failed due oil had got to the brushes, if yours is anywhere near this milage I would highly recommend install new starter at the same time.
https://mbworld.org/forums/c-class-w...ak-repair.html
Dave
I am capable of DIY this one, I have replaced starter, done the tranny fluid change, valve cover gasket etc but just wanted to be prepared before going in.
I will ask again so someone can chime in.
Is it possible to do the work from the top just by removing the air filter housing or I have to remove the starter to get to all the oil filter housing bolts?
Will take picture once I do it.
I am planning to change the entire housing instead just replacing the gasket., any thought?
I would be surprised if the housing is warped but then again over-torquing the oil filter cap over time might cause problems. My guess is that enthusiastic tightening of the cap coupled with age and hot/cold engine cycling causes the gasket to leak. But hey, it's all part of the Mercedes SLCS (Self-Lubricating Chassis System).
Further down the thread he links to a pdf with instructions on how he did the repair, it looks like he didn't even have to go in from the top.
I read about a one thing before I do anything to make sure I can remove the hose clamp for the coolant inlet hose. Any idea why this one is so difficult? Awkward location or need special tool?
I had to remove the starter. First, I removed the air filter box but that did not give enough clearance to do the work, someone may be able to but I wasn't.
So, after removing the starter the 5 bolts are of the oil filter housing were accessible but I needed a flexible hose clamp plier to remove a hose going into the water pump. I put the starter back and called it a day.
It's very difficult to work under the car, I used a pair of ramp which don't give enough clearance to work using 2 hands.
I will take it to a shop and get it taken care of.
Question to the ones who have done this, how difficult it is to remove the hose from the housing after loosening the clamp with this tool now, which prevented me from finishing the job last time. Do i need anything special tools? I know the space is very narrow.
Question to the ones who have done this, how difficult it is to remove the hose from the housing after loosening the clamp with this tool? Do i need anything special tools?
Has anyone done this job so you can share if the oil filter housing can be removed form the top? Any tips and video link would be appreciated.
Here's the pic of the housing location in my car. I found some references when I googled for info but the W204 comes up with different housing location.
My car is a 2013 C250 sport.
I have the same model as you, and this project is still on my active list. Unfortunately, the camshaft adjuster replacement jumped to the top of the queue. Here are the steps from the WIS. From their description, it appears that you have to remove the intake manifold and the oil filter housing from the top side. I plan just to remove the starter first and see if it is possible to replace the gasket without the extra top side work.
As you suggested, the intake manifold , the air filter and housing = intake manifold? I may try that. I don't want to remove the bolts and be stuck with the hose clamp, that would not be nice.
