Instrument cluster not working?
Old Jan 14, 2022 | 06:37 PM
Azazel9's Avatar
W204 c200
Hey, new
here so go easy on me I'll try to give as much info as I can. I have a C200 CDI 2008, firstly my car would randomly die on start up, the car would unlock, all dashboard lights/radio/screen would work but when I go to turn the ignition it would completely kill the power to everything.
The only way to get it to work would be to wiggle the wire on the battery then everything would turn back on and start up again. After it happened 2 or 3 times I charged the battery up, and it stopped happening.
Now maybe 2 weeks later I've started the car up, and the clocks have stopped working, along with the controls on the steering wheel, the rest of the car all seems to have power and be working, it starts and the radio and rest of the dash works.
The strange thing is that since this has happened the clocks back Lighting is coming on, usually when the cars been left a few hours. even when there are no keys plugged in, and drains the battery overnight. I've put the keys in when the back-light is showing and it's the same situation as when it's not showing, car starts, everything works except the clocks and steering wheel controls.
I did replace fuse F28 and F5 after searching prior to writing this post - but that didn't work. So I'm thinking next thing I should probably try a new battery? Or should I be looking to replace the instrument cluster or both? If i need new clocks is there a way to show the correct milage of the car?
Attached a pic to show what I mean. Appreciate any help
Old Jan 14, 2022 | 09:24 PM
Mb4li5's Avatar
Mercedes c250 4matic
Check EIS
Old Jan 15, 2022 | 10:46 AM
Azazel9's Avatar
W204 c200
OK I disconnected the battery and charged it up, tested the Voltage after charging and its 12.2V.
Then I connected it back to the car and it read 12.1V, but the clocks have started working again. I'm not sure if this is because of the battery being charged because I did try that once before hand, or that I hadn't disconnected the battery since putting in the new F5 fuse, and maybe that had an effect with resetting the cluster or something? I dont know.
I also tested the voltage on start up and it dropped from the 12.1V to 8V, before going back up. from reading having a drop that big can be a sign there's an issue with the battery?
The clocks are working but the original issue was back, where the car would die on start up, and you'd have to move the wire on the battery for the power to come back on? I've added 2 pics, so you can see that once the wire has been moved the light in the boot will come back on and you know the powers back.
Am I best off replacing the battery? Or is this caused by something else? Now the clocks are working I assume the back-light won't stay on and the car won't drain again, the car still starts ect and there's power to everything, just sometimes you have the move the wire to enable that.
Thanks for any help.
Old Jan 15, 2022 | 10:47 AM
Azazel9's Avatar
W204 c200
Originally Posted by Mb4li5
Check EIS
Whats the EIS and how do I check that? Sorry this is all new to me
Old Jan 15, 2022 | 03:48 PM
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
Hi
The two problems I see are 12.2v after charging and 8v when cranking.
There is a problem with your battery replace it asap it should be 12.8v after charging and drop to something like 12.1v when cranking.
Old Nov 5, 2022 | 01:50 PM
claudeisaac's Avatar
Mercedes Benz C200K (w204 - m271)
Did you find a fix for this? Exact same issue with my w204.
Old Nov 5, 2022 | 04:57 PM
Azazel9's Avatar
W204 c200
Yeah it was the clocks, sent them to ECU testing and had them rebuilt, been fine ever since.
Old Dec 15, 2022 | 10:32 PM
Iz96's Avatar
12 C300 4matic
Do you mean just replaced the instrument cluster?
Old Dec 16, 2022 | 05:07 AM
Azazel9's Avatar
W204 c200
Not replaced but had them repaired. Theres a company called ECU testing where you can just remove and post the part to them, and they also test clusters. Think I paid around £180 for the test and repair, if they test and cant find a fault I believe they only charge £50 for the testing fee.
They found a fault and repaired it, clusters been fine ever since.
Edit: This was the site I used, https://www.ecutesting.com/
Old Feb 15, 2024 | 01:08 PM
gabyjohn's Avatar
Mercedesc C 200 Kompressor
Speedometer cluster issues
Hey, new
Hello everyone,
I want to let you know I have the same problem for few days.
My car is C200 1.8 Kompressor. 2009.
Even if the engine is off that light os not coming off.
After I my battery was dead overnight, when I started with jump leads the cluster was work I only for few seconds and then comeback to the same light.
What do you think I should do please ?
On tester says… cluster faults …
Many Thanks
