The chassis is lit
Old Jan 26, 2022 | 10:47 AM
Marktee's Avatar
2012 C250 Turbo M271 EVO, 08 X3, 08 328i
The chassis is lit
I do not know if I have to start a new thread for every question I encounter on my car or just add the question to the original thread....
On top of the trillion things I am facing while trying to fix the car, I found out that the car has a short as well. I clamped the test light to the battery negative terminal and touched the probe on different parts of the car, the light came on dim and flickering. I checked it with multimeter and got a few voltage on the meter.
I tried the process of elimination to find the culprit by leaving the test light lit and removing the fuses one by one on on both frontal fuse box in the engine compartment and trunk box but the light never went out...There are no other fuse boxes in the car...
Would oil on wires and connectors
Runderneath the car cause a short like this?
does this connector supply the power to all the fuse box. I did not get any Voltage when I checked it
Old Jan 26, 2022 | 08:38 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
No, you don’t have to start a new thread for every problem. One thread for the renovation would allow interested readers to follow and provide suggestions.
I don’t mean this as an insult, but this is a resurrection rather than a repair.
What you need is a knowledgeable acquaintance that has one just like it. Let me suggest looking into one of the chapters of the Mercedes Benz Cub if America. From your profile it looks like you live in the Dallas-Fort Worth area. MBCA has both a Fort Worth and a North Texas chapter.
I resurrected a mid 60s American car this way, although it was a lot less complex than Benz.
Old Jan 28, 2022 | 12:26 PM
Marktee's Avatar
What is the function of this relay attached to the negative terminal of the battery. Is it Possible that I messed it up when I accidentally Touched both ends of the cable.
would the car Start despite the seats are disconnected and out of the car?
Old Feb 1, 2022 | 06:34 PM
Gazwould's Avatar
S204 C250 CDI Sport
That Hyundai component is to do with Stop Start , also the way it charges the battery ( Smart charging ) because of stop start , also something to do with brake HOLD too ?
