Brake light out no melted harness
Old Feb 19, 2022 | 02:32 AM
Cclasss's Avatar
W204
Hi everyone,
I seem to have a some what unique issue.
My 2012 w204 is displaying "left rear lamp out" warning on the dash.
Fine I thought, so I replaced the globe.
Unfortunately it didn't fix the problem. 1 of the 2 brake light bulbs are still not lighting up.
So I did some googling and found its common for the earth wire to melt. I'm fairly sure this is not my problem as the wires and connections look fine.
I've tried different globes, sprayed some contact cleaner and checked connections. Everything seems fine but the single light on the in the left rear light still isn't working?
Any help much appreciated.
Thanks.
Old Feb 19, 2022 | 08:14 AM
JimMBC300's Avatar
2008 C300
You may want to use a multimeter and an insulation-piercing probe (standard push pin works) to see where voltage is and isn’t. A 06/14/2021 posting (search “rear fog light” on this forum) by antiguangenius on this forum includes a wiring diagram that will be helpful.
Old Feb 19, 2022 | 07:29 PM
Cclasss's Avatar
W204
You couldn't link me to that post or wiring diagram by any chance? I tried searching but nothing came up.
Is this issue common? (1 brake bulb out) it seems very strange to have just one drop out and not both in the same light.
If it is common, what are the common reasons for it to happen?
Thanks.
Old Feb 19, 2022 | 08:25 PM
JimMBC300's Avatar
2008 C300
https://mbworld.org/forums/c-class-w...ight-swap.html
The overheated connector is a common problem, but the ground pin was the culprit because that pin has the highest current load. I don’t recall reading of tail lamp connector pins for individual lamps failing. If you find that the connector is the problem, applying some contact lubricant may help.
