Changed Transmission Mount on 2012 C250...
I was about to take the car into the shop but decided to change the transmission mount myself before taking it in. The transmission was a lot lower, I think I had to raise it up a half inch to get everything installed. On the test drive, it was like night and day. The car was quiet, it was smooth, the power was responsive, the lag was gone and the errors were gone. This was the car that I was expecting when I bought it.
Could a transmission mount cause that many problems in the car? Been driving for a week now and am amazed at the difference.
I'm just wondering if the transmission was so low it wasn't outputting the engine power properly and caused a whole set of issues.
I updated my post to reflect that I actually bought the car in December 2019, not 2012 as originally posted.
Here is a pic of the old one that came out. The inner support bracket is much lower than the new one. Also some of the rubber at the bottom seems to be missing.
Pelican parts has a write-up on this and there are a couple of good videos available on youtube
You will need a low profile jack and 2 jack stands.
All I know is the car is responsive, smooth, and quiet and power is on demand. The car has never felt like this in 3 years of ownership. Hopefully I've saved a few thousand dollars in repairs, but like I said, I've been waiting for the other shoe to drop.
Hopefully nothing else goes wrong!
Again, I just changed the transmission mount. As with the original post, car is driving and shifting smooth and road noise is gone. The last transmission mount was a Corteco brand, this time I used a Bilstein.
I guess these transmission mounts don't last very long and it needs to be part of your maintenance. Going to change my parents C300 and see it helps their car too
With that said, maybe you could upgrade to a more durable transmission mount? Creative Steel makes a poly one - https://creative-steel.com/shop/merc...mission-mount/. I've used their mounts & bushings on my CTS-V for years, everything has worked great and they're good people. (It's a small, family-owned business, as far as I know.)
Like I mentioned previously, I've been waiting for the other shoe to drop, but the times the car has thrown this code, a new transmission mount seems to work for me. When I tried clearing the codes prior to a new mount, the codes would clear but would inevitably come back in a few days. But once a new mount goes in, codes don't reappear until a the mount is again worn.
The mount that I just removed, all the edge bushings were gone, just the middle bushings remained, which were cracked. I have never seen anything like this before on other cars I've owned and I am in a bit of disbelief. But my butt dyno and the feel of the car is night and day whenever a new mount goes in
I will change the 2 engine mounts soon, will see if it makes the transmission mount last past 30k
The ragged stuff is just residual rubber.
