[Tutorial] Loud Blower Motor Fix
Old Mar 27, 2023 | 05:07 PM
dermotkirk9's Avatar
2009 C220 Sport AMG
Hi
so I recently had the issue of a loud blower motor that gave off a constant squeal on lower speeds
This is how to fix it without any replacement parts and only a few tools
Panel under dashboard lowered from passenger footwell to gain access to the blower motor
Bottom view of the blower motor assembly
Use a sharp drill bit and only drill the plastic housing! It is around 3mm thick plastic
Finally pack some heavy duty grease into the hole you drilled previously & cap it off with a rubber grommet
enjoy your nice quiet fan
hope this helps some of you guys
Old Mar 28, 2023 | 08:50 AM
W205C43PFL's Avatar
Originally Posted by dermotkirk9
Hi
The idea is great, thanks for sharing. Hope it holds.
Old Mar 28, 2023 | 09:08 AM
2009 C220 Sport AMG
I am driving the car today after doing this and the fan is completely silent, but definitely give it a try and report your findings
Old Apr 4, 2023 | 09:47 PM
W205C43PFL's Avatar
Thanks OP, really appreciate you posting this and your update on it post rectifying it,
Old Apr 5, 2023 | 06:47 AM
gamma300C's Avatar
2009 MB C300 Sport 4matic
A 5 or 10 cc syringe might make the grease packing part easier..;.
Old Apr 5, 2023 | 01:32 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Great post! This is the kind of thing we’ll need to keep these cars running as they age and parts are no longer made. The W163 SUVs (1998-2005) are running into parts availability issues taking them out of service now.
BTW — What was that red grease that you used? I’m considering wheel bearing or CV joint grease on mine.
Old Apr 5, 2023 | 02:43 PM
alynch's Avatar
2020 C300, 2013 C250, 2000 Boxster S
Excellent maintenance post! I plan to use this when I get around to the intermittent squeaking in cold weather:
https://www.fcpeuro.com/products/cv-...red-line-80401
I bought it to repack the rear wheel bearings on the Boxster.
