C/S button inoperable
Old Apr 10, 2023 | 12:17 PM
C300NC09's Avatar
2009 C300 Sport
Anyone have experience with a C/S button on a 2009 C-300 Sport that doesn't change the transmission shift profile from Comfort to Sport when pushed? It worked in years past but now when pushed there is no change from C to S mode. Trying to troubleshoot. The button is left of the gear shift. Thanks!
Old Apr 10, 2023 | 09:07 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
I think the literal button underneath might be broken
Old Apr 11, 2023 | 07:34 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
I do hope it is stuck at the S mode as that is the last year it does not revert back to C mode when you restart the vehicle. Did you pullout out the trim around the shifter to do some work? you might have pulled the wire or something. Pull it out and reinstall it. It that does not work try buying the same part on a wrecker and cross your fingers. There is no need to reprogram anything when replacing that switch so hopefully it is just a dead switch.
Old Apr 13, 2023 | 04:01 PM
C300NC09's Avatar
2009 C300 Sport
You are both correct. The switch/button failed. I replaced it with a new one from MB and now it is working fine. Took 5 minutes max to swap it out. Thanks!
