Leaking water passenger side
Old Apr 11, 2023 | 11:44 PM
beaz12's Avatar
Mercedes Benz c300 2011
Hello,
I have a 2011 C300 Mercedes and theirs is a lot of water under the passenger seat to the back floor. I push down on the carpet in the back and more water leaks started to come from back metal pieces. I removed the scuff plates in order to get the water out and was able to.. I live in Miami Florida and it’s been raining everyday so the next day when it rained again the same thing happened.
Any idea what could be the problem.
Thank you
Old Apr 12, 2023 | 06:32 AM
alecmascot's Avatar
W204 C220CDI 2011
Check that the drains are clear at the base of the windscreen, near the wiper shafts.
Old Apr 12, 2023 | 08:50 AM
alynch's Avatar
2020 C300, 2013 C250, 2000 Boxster S
What alecmascot recommended plus the sunroof drains.
Old Apr 12, 2023 | 12:17 PM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
YES, sunroof drains are usually the culprit.
Old Apr 12, 2023 | 01:14 PM
beaz12's Avatar
Thank you all for your replies, I checked the sunroof drains and they were clogged was able to clean them. Hopefully no more water comes into the car.
Old Apr 12, 2023 | 01:31 PM
S70Houston's Avatar
If your sunroof drains were indeed clogged and are clear now, I am pretty sure you have solved your issue.
