Srs codes help
Old Sep 22, 2023 | 07:43 AM
alenpepic's Avatar
2005 CL55 (sold) C63 Coupe 2012 p31(sold) Audi 330awhp E55 511WHP(sold)Z06C6 550whp C63 LTH
Srs codes help
Old Sep 22, 2023 | 07:44 AM
alenpepic's Avatar
Due to the short in the circuit and large amount of codes being thrown.
Can it be said it’s a failure of a module itself ? I still can’t find someone who has a similar issue
Old Sep 22, 2023 | 11:04 AM
JettaRed's Avatar
Veteran: Army
A common problem with the C-Class is, as they age, the wiring going to the seatbelt connector breaks and you need to replace the whole connector. Search YouTube. I think FCP Euro has a video on how to replace it.
When mine broke, I did not do a scan like you did. However, I have found that one problem can throw a bunch of codes that seem unrelated, but actually are.
This may also help: https://forums.mercedesclub.org.uk/i...n-squib.87064/
Old Sep 22, 2023 | 01:36 PM
alenpepic's Avatar
fair enough but wouldn't it link it to the seatbelt-- through all these errors I dont know if i could connect the dots to the seatbelt connector. i peeped the post you sent me seems like their code is different
Old Sep 23, 2023 | 12:54 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Not to be insulting, but:
What caused you to scan the SRS system in the first place? Do you have any indications other than the codes? Did you check to see if the airbag fuse was blown? The codes are stored. Do they come back after clearing them? My next place to suspect would be the pre-fuse block.
Old Sep 23, 2023 | 09:22 AM
JettaRed's Avatar
Veteran: Army
Well, maybe. Don't try to make a logical connection between the codes. If you are a software engineer and had the source code, MAYBE you could trace the logic. Otherwise, fix one problem, clear codes, and see what returns. This guy explains that rather well:
