09 Mercedes C300 W204 Rear Right marker light not working
Old Sep 25, 2023 | 01:47 AM
trodhome3421's Avatar
09 Mercedes C300 w204
09 mercedes C300 w204.
Rear right back marker light not working
Checked with meter
No voltage
Maybe blown fuse
Need location of blown fuse
Help would be appreciated
Thanks in advance
There is a message on dashboard ' check Rear right marker '
No signs of melting or damaged light socket
Old Sep 25, 2023 | 01:49 AM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
So there are no fuses for most lights in this car. The rear SAM is the module that control all the lights in the rear. Do you have messages on the instrument cluster for the lights that do no work?? One of the most common issue with W204 chassis cars is the ground. Check the connector to see if is has overheated and melted.
Old Sep 25, 2023 | 12:13 PM
TimC300's Avatar
Use the multimeter and trace the wire back to the fault.
Old Sep 25, 2023 | 04:04 PM
I used a tester & checked it had no power ( 12 volts )
I will check with the multi meter this evening
Thanks a lot & appreciate your reply
I hope it would work soon
Best regards
