The car won’t Start 🥺
Old Sep 29, 2023 | 10:16 PM
CedricShelby's Avatar
C 300
Unhappy The car won’t Start 🥺
Hello,
I'm new to this forum.
I just purchased a car from a private seller. 2009 Mercedes C 300 4matic luxury. We jump-started it and it ran fine. When I got home the car would not start again. I purchased a new battery and it still doesn't start.
It just clicks - anybody - help!
Old Sep 30, 2023 | 08:04 AM
JettaRed's Avatar
Veteran: Army
There are usually two batteries, one to start the car and one to operate all the electronics. Which one did you replace?
Old Sep 30, 2023 | 08:09 AM
JettaRed's Avatar
Veteran: Army
One more thing, as a new Mercedes owner, get yourself a Mercedes specific scanner--not some generic OBD reader. It will pay for itself almost immediately. You now own a sophisticated automobile (though old) and need to be prepared to spend money where needed. The first step is to get a scanner!
Check Amazon for:
  • iCarsoft MB V3.0 (not MB II)
  • Launch Creader Elite MB
  • Foxwell NT510 Elite
  • BlueDriver
Old Sep 30, 2023 | 08:50 AM
C 300
I have replaced the primary battery. Do you have any idea where I can find the location of the secondary battery?
Old Sep 30, 2023 | 08:54 AM
C 300
That's a fantastic idea! I will definitely do it today.
Old Sep 30, 2023 | 09:01 AM
gamma300C's Avatar
2009 MB C300 Sport 4matic
Your 2009 does not have a secondary battery..just the "usual" one in the front PS side engine compartment. Confirm your new battery has good voltage at rest, 12.8 V or there abouts. Do your headlights, accessories work with the key turned to ON position, all dash lights illuminate ? If headlights weak, battery not charged...if headlights dim while trying "Start", same thing. Batteries can have a dead cell defect off shelf. Did you try to jump start it again ?
Old Sep 30, 2023 | 09:10 AM
C 300
I checked out all the scanners you recommended and thank you. I went with BlueDriver, which was the least expensive option.
Old Sep 30, 2023 | 09:15 AM
C 300
I tried jump-starting my car, but it didn't work. I then bought a new battery and tried jump-starting it again, but it still didn't work. I took the new battery to two different places to get it tested, but both places said that it was fine.
Old Sep 30, 2023 | 09:26 AM
C 300
Today my new scanner will arrive after 5. I hope it will help me determine whether it's the alternator, fuse, or something else.
Old Sep 30, 2023 | 10:41 AM
gamma300C's Avatar
Nothing powers up..lights, horn, dash lights ?? Hopefully your OBDII connection is up. If no sign of power anywhere (Edit: if it "clicked" on Start, volts are flowing somewhere), keep the idea that the pyrofuse and it's nearby fusible links may be the problem but your C300 isn't there yet hopefully.
These replaceable fuses are under the plastic cover that your + jumper tab juts through, red sliding cover. These blow when a major surge occurs....failed alternator regulator allowing overcharge, shorted high amp accessory like starter, alt. , and rarely from jump start gone awry. Forum Search , Google Search has info. about this, where you can get new fusible links, DIY stuff if it ever comes to that and you are in to it.
Good luck ...you have a good model W204 IMHO.
Old Sep 30, 2023 | 10:53 AM
Demvang's Avatar
2011 C300 4Matic Sport
I would check the starter fuses.
Fuse diagram
Old Sep 30, 2023 | 11:26 AM
TimC300's Avatar
I would try wacking the starter with a hammer but its a pain to reach from underneath, I got a jeep to start that way but only once or twice before I ended up replacing the starter which was the issue. Not sure it will work, but cant hurt to try. If you have a multimeter check the battery voltage, then check it when youre turning the key trying to start the car to see if its drawing power. I doubt its the battery since you went through 2 plus had it jumped. Could be the starter, the wiring like bad ground, bad connection to the starter, maybe a relay.
Old Sep 30, 2023 | 06:24 PM
JettaRed's Avatar
Veteran: Army
BlueDrive is good for scanning and clearing some codes, and it will support multiple vehicle brands, but it is not as full-featured as the others. But for now, you may not need those features.
(FWIW, I have collected multiple scanners over the years and do not regret having them. The BlueDriver you can keep in the console or glove box. The others would have to fit elsewhere.)
Old Sep 30, 2023 | 08:31 PM
C 300
Thank you! This will be very helpful. I'll check it first thing in the morning.
Old Sep 30, 2023 | 08:33 PM
C 300
I understand. I am currently checking the link you shared. Thank you!
Old Sep 30, 2023 | 09:02 PM
C 300
Old Sep 30, 2023 | 10:12 PM
JettaRed's Avatar
Veteran: Army
I’d focus on the last two dealing with ignition.
Old Oct 1, 2023 | 11:03 AM
TimC300's Avatar
is that the first time scanning the vehicle? If so may try clearing the codes, then try starting it a few times to see what current codes show. First time I scanned with a good scanner it had a bunch of codes, i cleared them and most if not all were gone.
Old Oct 1, 2023 | 11:16 AM
TimC300's Avatar
Not sure if you answered this but is anything turning on when you turn the key, are the dash lights lighting up, does the radio turn on etc?
Does the sterring wheel unlock withthe key in? With the key out can you turn the steering wheel?
Do you have a 2nd key fob, try starting with that one just to check.
Old Oct 1, 2023 | 06:50 PM
C 300
Hello Again,
Day two
The car powers up and everything seems to be working fine, but it simply won't start.
Old Oct 1, 2023 | 06:53 PM
C 300
Oh, I didn't realize that. I wanted the codes to be included so I could understand what was happening. However, I can delete them and start over from scratch.
Old Oct 1, 2023 | 06:58 PM
C 300
Everything still works: radio, headlights, and instrument panel. However, the car doesn't start and only emits a moaning sound.
Old Oct 1, 2023 | 07:08 PM
C 300
headache
I'm excited to give these awesome suggestions a try! But if for some reason they don't work out, I'll need to reach out to a pro and have them tow it away.
Old Oct 1, 2023 | 07:16 PM
TimC300's Avatar
How about the steering wheel lock:
- without the key in can you turn the steering wheel?
- With the key in can you turn the steering wheel?
I ask because I found a few people who had similar issues and it appeared it was a faulty electronic steering lock (ESL).
The reason to delete the codes is they may have been from awhile ago, one time issue due to a gremlin and they arent current. For example if you disconnect the battery a code or two may pop up as a result, but the codes arent relevant anymore.
Old Oct 1, 2023 | 08:12 PM
C 300
Regarding the steering wheel, it moves about two inches in either direction, regardless of whether the key is in or out. I cleared the codes, and this is the only issue that remains. See attached.
