W204 Subframe bush sizes
Hi Guys
I own a 2009 C250 C-Class, so non facelift. i bought a new subframe on ebay, provided my VIN and Reg etc, but is appears they have shipped me a facelift subframe with 84mm front bushes, will this fit the non facelift? It looks as if might with the rubber bush in the subframe being larger diameter, but did MB also make a change to the top part that fits into the shell/chassis etc?
Any advise gratefully received.
Kind regards
Kevin
Kind regards
Kevin
I looked on my parts diagram and it has two bushings listed. The 204 # says 76mm and when I look it up online it shows as fitting and for 2008-2014. The 205 # says 85mm and when I look it up online it shows as fitting 2014-2023.
Is there a part# on the subframe?
