C300 Stock Resonator Dimensions
Hello, does anyone know what the dimensions of a stock resonator for a 2009 c300 is? I haven't been able to find dimensions from Mercedes parts description and cant find a good scale picture of one. I have a xpipe installed on my car and thinking of getting a aftermarket resonator to cut down on vibrations/drone. If anyone has one sitting around would really appreciate a quick measure of the width and length.
I did a rough measurement reaching under using a yard stick so its not exact. I measured joint to joint and was getting 20-1/2" long. Width around 8" but I couldnt see that well, probably a few inches wider.
How on earth are you having a drone on a xpiped C300? A lot of us with an Xpipe on the c300 don't have such drone. What xpipe did you use? majority of us here used the magnaflox xpipe. The xpipe should be installed where the original resonator is so not sure where you placed your xpipe.
Ahhhh you replaced the mufflers. ThAt is your problem. You should have placed the xpipe first. Do you still have the stock exhaust? If not, time to find a wrecker and get one.
