C300 Passenger side Primary Cat removal
Pretty much what the title says. I have a 2010 c300 V6 auto and I’m having a hard time removing the Primary cat on the passenger side of the car. I can’t seem to get to one of the bolts. I was wondering if anybody had a write up on it or tips and tricks. I have to remove the exhaust to replace the transmission as well as the cat’s damaged when the front drive shaft broke it split the cat open. Any body got any tips and tricks for me or possibly a guide or photos?
Received 1,849 Likes
Search YouTube for bolt removal is probably your best bet. Your problem is not a Mercedes one; it's generic.
Thank you, Seger
I do not have access to everything but in the instructions for removing the right side exhaust manifold it says to undo the catalytic converter flange first (step 4), so I'm thinking the exhaust manifold does not have to be removed.
The note for working on that flange is AR49.10-P-7100CW which I dont have.
I remember looking at my exhaust thinking it looks fairly easy, I thought I had a hole in my passenger exhaust manifold. Can you reach the bolts from the top?
I was looking at photos i took and I know on the drivers side the bolts can be reached from the outside/left from underneath. Looking at the passenger I'm thinking the same, reach them from the outside/right side.
Drivers side can see the bolts:
unfortunately the passenger side doesn't show the bolts. But it looks too tight on the left of the pipe.
Ok that gives me good hopes that it says I don’t have to remove the exhaust manifold, I was not looking forward to that if I did. And yes the drive side primary catalytic converter was a lot easier to remove had it off in a couple minutes. I’ve been having troubles with this one because not only can I not even see one of the bolts the one I can’t see is proving difficult to get off. Part of that is I have to use a knuckle to get the socket on the bolt where as for the drive side the socket and extension lines up perfectly. Do you think I’ll have to pull the heat shields to get to the bolt? I’ll take another look at it tomorrow night and I’ll update you guys if I did get it off and any tips or tricks I got for the next person. Thank you again and if anybody does have any more tips or tricks before I try to tackle it again please LMK lol.
Here you go.
(Tim, you really need to get a copy of the WIS.)
Thank you so much this is literally exactly what I was looking for. I was curious how do you guys get copy’s of WIS? It might save me from posting in the future and save some of your guys time on my dumb questions 😅
There are a couple of ways to get WIS. The BEST place to get a copy of WIS and EPC is from @BenzNinja since his are "legitimate" copies that run natively in Windows. The copies you will find on eBay will usually require you to run them on a virtual machine, such as VirtualBox, which is OK but you may not be able to print. The reason is that the applications are activated based on the MAC address of your network "card" and require a "key" to work. VMs make that simpler, but there are drawbacks. Getting the software from BenzNinja includes a copy of XENTRY and other good stuff. XENTRY is the Mercedes diagnostic system. It requires a vehicle interface device called a C4 multiplexer and a laptop or tablet running Windows.
Not sure where you are in you Mercedes journey, but if you are around for long, you will eventually need XENTRY.
(By the way, BenzNinja provides lifetime remote diagnostic support, including software upgrades, with membership. He has a promotion right now where the membership fee is credited toward his customized modifications, such as transmission modes activation, elimination of ECO Start/Stop, and others. The diagnostic services are included in the membership free. A couple trips to the dealer for problem diagnosis will easily pay for the membership. And all of this is from the comfort of your home at your convenience.)
BenzNinja (02-22-2024)
2010 ML550 VIN WDC1641722A564750, 2010 B180
The WIS .png[/img]
There are a couple of ways to get WIS. The BEST place to get a copy of WIS and EPC is from @BenzNinja since his are "legitimate" copies that run natively in Windows. The copies you will find on eBay will usually require you to run them on a virtual machine, such as VirtualBox, which is OK but you may not be able to print. The reason is that the applications are activated based on the MAC address of your network "card" and require a "key" to work. VMs make that simpler, but there are drawbacks. Getting the software from BenzNinja includes a copy of XENTRY and other good stuff. XENTRY is the Mercedes diagnostic system. It requires a vehicle interface device called a C4 multiplexer and a laptop or tablet running Windows.)
