Ambitious idea transmission upgrade
Old Dec 31, 2024 | 03:28 PM
usual suspect's Avatar
I have a c200 kompressor that I have an ambitious idea and want to know wht ppl if possible.
has anyone try to upgrade the 5 speed auto transmission to something more efficient like a 7 speed?
Old Dec 31, 2024 | 07:04 PM
JettaRed's Avatar
Veteran: Army
You might be able to REPLACE the 5G with a 7G, but I've not heard of it. You should look at this thread:
https://www.benzworld.org/threads/tr...to-5g.3047146/
Or you may want to replace the conductor plate and valve body with one from Victory Road Performance.
Old Jan 3, 2025 | 03:09 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Maybe doable, but lots of electronic issues. The 7G has sensor outputs that the 5G doesn’t have, so maybe needing new ME software, seeing if the existing ECU can handle it, maybe even new wiring harness, and maybe new compatible instrument cluster to display gears 6-7. Need to get those issues sorted out before moving forward.
Old Jan 4, 2025 | 04:50 AM
bazzbazz's Avatar
C200 w204
With all the possible incompatibility issues between the 7G gearbox and all the other ECUs/Nodes in the car I say you'd be better off to buy a new car with the 7G+ gearbox.
I mean lets be honest . . . . what could possibly go wrong!
(Unless you're doing ALL the work yourself and working on Murphys Law with the possibility of everything that can go wrong doing so, with your love of gambling and are a true sadist.)
P.S. I'm not a pessimist . . . . . I'm a realist.
Old Jan 4, 2025 | 09:14 AM
JettaRed's Avatar
Veteran: Army
I love how newbies ask a question and then never come back to discuss the answer.
Old Jan 4, 2025 | 10:58 AM
W205C43PFL's Avatar
Happens... guess life moves on, or someone have the same idea and resurrect the thread down the road : )
Old Feb 27, 2026 | 01:10 PM
ScottC2's Avatar
2023 EQE SUV 500 4Matic
I have K32 (Active Lane Change Assist). It works -- but I almost always forget to use it. Guess this is the result of driving 50 years the old-fashioned way
Old Mar 1, 2026 | 07:01 AM
ScottC2's Avatar
No - That's lane-keeping assist.
@J_Boxer, on a different thread, posted this good description of K32.
K32 (Active Lane Change Assist): This is the standard "tap-to-pass" system that most of us with the Driver Assistance Package (DAP) have. It is Driver-Initiated. You tap the stalk, the car checks, the car moves. It will not move back on its own.
https://mbworld.org/forums/eqs/92081...hange-k46.html
Old Mar 2, 2026 | 12:01 PM
Silverstar92's Avatar
2019 Mercedes-Benz C300
I dug around a bit to see if anyone has actually tried this 5-speed to 7-speed swap on a C200 Kompressor. Short answer; I couldn't find a single person who has done it. Looks like you might be venturing into uncharted territory here and I would love to know how it goes.....All the very best
