Mercedec c300 w204 Stuck in reverse
I was Parking, threw in reverse, pressed the gas, it does not respond, the engine is running but the car does not move, after I released the brake, it began to roll, stopped, threw the handbrake, , threw it into parking, turned off the engine, after I turned on the engine, the lever is in parking, but the car itself is in reverse, that is, the panel shows reverse although it is in parking and the rear entry camera turns on, I change to drive, it still remains in reverse, then errors began to appear on the panel, one of them "Malfunction of the system held.passenger Return to the maintenance point" and a couple more errors. I called a tow truck, brought it home, they advised me to remove the stamps for a couple of hours, removed it but still did not help, I also can not start the car because it is stuck in reverse, this has not happened before.
Mercedec c300 2012 w204
