Check Engine Light - Error Codes 0017 & 3539 on C200 Kompressor (2009)
Old May 10, 2025 | 08:48 AM
VIINAR's Avatar
C200
Hi everyone,
I drive a 2009 Mercedes-Benz C200 Kompressor, and recently I've been having issues with the check engine light coming on.
I took the car to a mechanic who scanned it with a diagnostic tool, and these two codes came up:
  • 0017The position of the exhaust camshaft (cylinder bank 1) is implausible relative to the position of the crankshaft
  • 3539The boost pressure deviates from specified value
The mechanic advised that the Exhaust Camshaft Adjuster needs to be replaced and the engine re-timed to fix the issue.
Has anyone here dealt with a similar problem? I'd really appreciate any advice, feedback, or steps you took if you had the same error codes. Just want to be sure before committing to this repair.
Thanks in advance!
Old May 11, 2025 | 01:16 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
The advice seems appropriate for the symptoms, but before committing to this expensive repair, repost this to the W203 forum where the M271 Kompressor engine is more common.
