Running lean
edit: this is an 2011 Mercedes-Benz C300 and the work that been done with it below.
This may give you ideas to check. I'll have to look further into those specific codes. https://mbworld.org/forums/c-class-w...ease-help.html
Im not sure how detailed that scanner can pick up fault codes. Where there any other fault codes?
Ok so update I was looking around in the engine to see if there was going about the June 1st to make sure I can make it down to the airport (family and I currently on vacation) and found that I forgot the hoes that connects between the MAF sensor and throttle body (I thinks it called the crankshaft?) and that help with it from dropping as much.(kind of forgot cause it been a few day) but I do have a few questions like I use cruse control a lot so when I turn it off like letting of the gas is it supposed to go down a little to like for example from 1900~ to 1780~ at like 60~ mph? It was like this when I bought the car and I thought it was normal but honestly after look more into the car I’m not sure. My second question is what is the fuel economy on this engine supposed to be? Online I’m being told 24-26 mpg another said 30.4, and based of buying this car was saying 17 city and 21 highway. I get it based of your driving but some days I’ll will get like 31 mpg and then other days 23-25(I do live in a the middle of nowhere with a bunch of old people around so idk I just would like an idea of what I should be getting) I’ll give more updates when I get back from vacation.
I never use cruise control so not sure. I dont even know how to use it.
I have the M272 with 160,000 miles and I drive normal, no speeding around or racing the engine. Around town the average MPG will be around 19-22. Cruising on the highway 25-28. Thats combined miles driven from start.
The cruise control isn’t too hard to understand, there’s a stock above the indicators and headlight, Mercedes has a video.
thank you though cause the day I did find that hoes that wasn’t put on. I did get about 28 mpg though it has only been one drive. I did check if there was any pending cods or something and came back with nothing. So I am more confident that I have fixed the issue. I do think there a small vacuum leak since when you let of the gas the rpm lower just a small bit so I’ll still check on that.
Can search around for deals, Amazon or AliExpress. I've seen them under $100.
The 4 below I hear are all good.
Since I had the car around 5yrs now I never saw it go past 25mpg. Around town id check and see it around 19mpg.
This past winter I did nothing to the car, didnt work on it or replace anything. Only thing I can think of is I did buy 2 big value size bottles of Techron. I used one bottle per the directions, 1oz/gallon. Then the 2nd bottle I would use 2oz when getting gas, wasnt a full tank since like to get gas before it hits 1/4.
I dont put many miles on the car so it took me awhile. Then I started seeing the gas mile go up and up. Went to the store earlier driving backroads and saw it at above 23mpg. I'll also say the car is running fantastic.
if I had this to check the transmission, it probably wouldn’t had been so messy for lol
I did get fuel cleaner and see if that was the case long ago but I should keep doing that since I’ll be getting close now to 100k. Do you recommend that?
I'll get it at my local Napa Autoparts when its on sale. Right now its $12.99 for the 32oz bottle.
I've also used Seafoam though I get that mostly for my small engines. I think that stuff 100% works at keeping gas fresh in my containers. I have a small lawn and it only takes me 20 minutes to mow it so my 2 gallon gas container lasts me all year and i've never had any fuel related issues with my mower, weed eater or snow blower. I'll even leave gas in my pressure washer all year and that thing starts 1st pull every time.
also I drove the last few days and yesterday and got about 28-29 but later yesterday I got the same code again that it was too lean.
