Washer Reservoir issue
Old Sep 12, 2025 | 09:05 AM
jetson's Avatar
none
I went back to MB dealer and spoke with a service tech about the heat exchanger lid, coil and washer reservoir. All he would/could say was that it is supposed to snap on and that it was difficult and had to wrestle with it. Not the information I was hoping for!
Old Sep 12, 2025 | 09:26 AM
TimC300's Avatar
Theres a used one one eBay cheap. Check if its the same part# as yours.
Old Jan 24, 2026 | 07:23 PM
benzcam's Avatar
washer pump hose connection
Originally Posted by jetson
Working on 2009 C300 4matic Lux. The washer reservoir was flashing low due being empty. Upon filling it was leaking where the pump connects to the little hose clip.. The hose clip has ears that attach to pump tip. When I took the hose clip off there is a wire inside. I removed the clip and just connected it with the hose alone. The tank is full but still flashing low washer fluid. Does that hose clip and wire have anything to do with it?
I have the same problem. I assume when you say you removed the clip, that you cut it off. When you attached the hose alone did you clamp it? Does the inside diameter of the hose match up with the pump tip? Thanks for your help.
