Run flat sensor inoperable
Old Dec 8, 2025 | 09:25 AM
BigJimmyLarge's Avatar
C204 C350 12
Hi guys had this pop up the other night after 25 30 mins of driving it made the car go into a sort of limp mode where I coupled get over 40 or 45mph
Turning of the ignition and firing it back up let it run normal for the next 40 or so mins but it did do it again today. 120k miles , the car is under warranty so I'm having it diagnosed tomorrow at a local indi but just wanted to ask on here of it's a common fault and what might have caused it.
Cheers
Jim.
Old Dec 9, 2025 | 10:26 AM
C204 C350 12
Originally Posted by Streibensie
Do you have your own scan tool? I don't know what that error means, but sometimes a sensor gets corrupted and needs to be recalibrated. You may need to use XENTRY to recalibrate or initialize the indicator sensor. Let us know what happens.
So the Merc indi I dropped it off to today has said they can not see any faults with the car and no codes. So they are trying to get the car to grow the code but having no luck.
Old Dec 9, 2025 | 06:41 PM
TimC300's Avatar
Theres a few threads on this issue. May give you some ideas what to check:
https://mbworld.org/forums/c-class-c...e-problem.html
Old Dec 26, 2025 | 04:20 PM
C204 C350 12
Any help with this would be appreciated thanks.
