Car won’t start c300 2011
Old Dec 17, 2025 | 03:05 PM
Gkbrans's Avatar
Mercedes-benz C300 2011 4matic sports
This first started when I went out and I went in reverse and it turned off , all the lights were on and the engine wasn’t on .
it happened again when I was coming home from work but I let it rest for 2 mins and cranked it and it had some trouble but it eventually started . And recent I went to start my car and it cranked but a weird noise in my engine started and then it smelt like smoke . Not too long on my screen it said engine will turn off in 3 minutes . So I took out my keys and was shocked . I open my hood and there’s smoke coming out of it . It was dark at the time so I couldn’t identify where it was coming from . I go to start my car and it won’t crank .i turn it to position one , it works , I turn it to position 2 all the lights pop up , it works but as soon as I try to crank it nothing happens !! I changed the battery , I changed the alternator . Before I change the starter I want to know if it could be something else ?
File Type: mov
Old Dec 17, 2025 | 03:12 PM
Gkbrans's Avatar
I’m hearing it could be the the solenoid or the fuse or the fuel pump
Old Dec 20, 2025 | 09:40 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
No Guess Necessary...
that is really a good possibility.
Use your scanner to read your fuel pressure.
You will know under 5mn.
Old Dec 20, 2025 | 10:03 PM
Gkbrans's Avatar
is there a specific scanner or I could do any scanner ? Also would you know how much a fuel pump is ??
Old Dec 20, 2025 | 10:42 PM
Helpful Troubleshooting Scanner
don't waste your time swapping good parts blindly... it's more likely the FILTER than the pump itself if pressure gone dismal: filter fries hot pump!
Double check LAUNCH cReader MB Elite... deals near $100.USD over night from AMZ prime...
Easy & powerful scanner (others ok).
Old Dec 21, 2025 | 03:27 PM
TimC300's Avatar
Did it smell like burning/melting electronics or burning oil?
Fuse 7 is the starter fuse in the engine bay. But check them all while in there. https://fuse-box.info/mercedes-benz/...uses-and-relay
If I needed a scanner I would buy one of the Launch scanners.
Old Dec 21, 2025 | 05:46 PM
Gkbrans's Avatar
does this mean I have a weak battery? And also I should get a new starter ?
Old Dec 21, 2025 | 05:49 PM
Gkbrans's Avatar
yes it smelt kinda like burning electronic . I turned off my car as soon as I smelt it . I just read the codes . Should be on the post above
Old Dec 21, 2025 | 06:36 PM
With 11.6Volt that is a low battery charge level.
The first screen showing 3 HARD FAULTS does not show what modules.
The second screen shows fuel code as STORED meaning not current.
So bottom line is aiming towards what... the ECU bad power supply relay ??
(not so much fuel pump here)
Old Dec 21, 2025 | 07:16 PM
Gkbrans's Avatar
so I should get better battery? And replace fuse ?
Old Dec 21, 2025 | 07:18 PM
Gkbrans's Avatar
also with the scanner I have I can see the data on the codes. I don’t know what to click to see specific data I’m looking for .
Old Dec 22, 2025 | 02:02 AM
And replace fuse ?
I wish things were always that simple.
New batteries can also get flat quickly.
Test is bettery can't hold well full charge.
Test what's wrong... fuse dont blow without cause.
Do you have a blown fuse?
Old Dec 22, 2025 | 08:41 PM
Gkbrans's Avatar
what does the codes mean ? The ones I showed on this post.
Old Dec 22, 2025 | 11:44 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Charm code 1108 is low voltage at circuit 87 relay. It’s a fatal error. I think 87 is related to ECU power.
Old Dec 23, 2025 | 12:50 AM
It’s a fatal error.
That means one of the F-SAM relay may have matured to require attention...
This undersized relay may become a staple maintenance item.
Some ppl use infrared camera
Some ppl use schematics
Some ppl use DVM
Almost there!
Old Dec 24, 2025 | 01:33 PM
Gkbrans's Avatar
would you recommend to check my fuses ? Or a new battery is needed ?
Old Dec 24, 2025 | 04:48 PM
TimC300's Avatar
I looked up the codes and they show a few fuses to check. I just skimmed the codes quick since i dont have alot of time at the moment.
Heres a link to where i was finding the codes. They are mostly listed under the "Manufacturer Code Charts". Codes arent in order so have to look for them out of order. https://charm.li/Mercedes%20Benz/201...8%20DTC%20%29/
Old Dec 24, 2025 | 06:54 PM
Gkbrans's Avatar
I replaced the battery for a better one recommended for my c300. It cleared most codes except the 1337 code . I tried to read the starter but I couldn’t find the data stream for it .
Old Dec 24, 2025 | 08:00 PM
TimC300's Avatar
Im not sure what communication with the starter would even be. When I look up that code it just mentions the alternator, not the starter.
Is the car still not starting?
Heres what it says for the starting function:
Old Dec 25, 2025 | 03:34 PM
Gkbrans's Avatar
yea car still won’t start . I’m thinking the starter is the problem . I changed my alternator a week ago . New and plugged in . Changed my battery , new belt . Still won’t start . I’m thinking the starter since that’s the only one I haven’t changed and I can’t read data stream to starter
Old Dec 25, 2025 | 06:43 PM
TimC300's Avatar
I was looking thru the electrical diagrams. It looks like the starter and the alternator are connected by + wire.
There is a LIN wire from the alternator to the ECU. LIN C1. Wonder if that has a faulty/loose connection. S-Prihadi knows alot about this stuff. Hes usually in the W212 section.
I cant post the full diagram due to its size. Heres a link to the diagram i was looking at: https://charm.li/Mercedes%20Benz/201...ging/Diagrams/
Old Dec 25, 2025 | 09:52 PM
Gkbrans's Avatar
so they didn’t install my alternator correctly? Or is this something I can fix?
Old Dec 25, 2025 | 11:59 PM
Odd Piggy's Avatar
There isn’t much information that comes directly from the starting/charging circuit, but what info there should be seems to be absent. That LIN circuit is a low speed serial bus sending basic charging voltage information. Check the connections on the alternator. Since the alternator is new, make sure they are tight. If there is a separate ground for the alternator, pay special attention to it.
Two other ideas popped into my mind about this issue:
First is an open fuse in the prefuse box. Check the wiring diagram from @TimC300 to see if the alternator output even goes through the prefuse or if it’s only the battery.
Next, as a last thought, is the Drive Authorization System. You may need to scan that on a cold start attempt to see if it is blocking the starter. With the right scanner you can determine which component was not satisfied and go from there.
Old Dec 26, 2025 | 03:13 PM
Gkbrans's Avatar
which fuses should I look at? 7? L? M? Or is this the wrong fuse box ?
Old Dec 26, 2025 | 03:15 PM
Gkbrans's Avatar
You mentioned a “ separate ground for the alternator “ what would that look like? If I were to look under my car what would I have to look out for? Sorry if I’m asking a lot.
