Anyone figure out how to attach the cargo net?
Old 11-24-2014, 03:55 PM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
Okay, I'm stumped. I tried to install the large cargo net/pouch that came with the car. The instructions show four attachment points in the trunk, with one of the four clips attaching to each of those anchors. The problem is that my car only has two anchors on the floor of the trunk, in spite of the fact that the instructions clearly show all four. I lifted the carpet thinking they may have been hidden, but there's nothing there.
No wonder it was left in an unopened plastic bag. There doesn't seem to be any way of attaching it.
Old 11-24-2014, 04:06 PM
jbbeauso's Avatar
2015 C400 4matic W205
I wondered the same thing....Right now I hooked two clips to the visible rings, and the other two on the side of the cargo hatch cover. Not sure if it's right or if there is a better way to do it.
Old 11-24-2014, 04:15 PM
StanNH's Avatar
I tried that, but it doesn't look right and there's no reinforcing at those points. I found pictures online that show it in a vertical position, attached to those plastic clips on the sides of the trunk near the lid, but the bracket isn't compatible with the hooks on the net ... plus they barely reach each side unless you put way too much pressure on the net and plastic brackets.
Personally, I don't think the net is at all compatible with the anchor setup used on the W205.
Old 11-24-2014, 04:43 PM
c4004matic's Avatar
Received 1,058 Likes on 698 Posts
17 E43; 21 GLS580
There should be 2 hanger hooks on the sides and 2 cargo hooks on the trunk floor.?
Old 11-24-2014, 04:44 PM
Merlin1's Avatar
W205 C200 Sport Premium Plus. October 2018. 1497cc with 48 volt battery eq
my UK C200 has four point to anchour on boot floor
Old 11-24-2014, 04:49 PM
StanNH's Avatar
It looks like US cars only get two floor anchors with a four hook net. That doesn't make any sense at all.
Old 11-24-2014, 04:52 PM
c4004matic's Avatar
17 E43; 21 GLS580
http://www.motorauthority.com/image/...xury-rwd-trunk
I know this is the older model, but if you take a gander you will see a little black hook on the upper lip of the trunk , I know there are hooks on the floor (4).
Old 11-24-2014, 04:54 PM
c4004matic's Avatar
17 E43; 21 GLS580
HMMMMM????? Dammit where is my car when I need it
Old 11-24-2014, 06:25 PM
Leslielp's Avatar
2020 CLA 250 4Matic Black
Interesting, I have four hooks in my trunk. two near the rear seats and 2 near the opening. Are we all talking about the same hooks, these are the metal loops that are part of the lining of the floor of the trunk. I would think the cargo net required hooks more to the top sides of the trunk
Its just too bad they did not go with the pull out cargo/bag tray that was on the Auto Show demos.
Old 11-24-2014, 06:29 PM
crxsnow's Avatar
2015 C300 4Matic Sport
I folded the backseat down to get a better picture of where the other hooks are located. If you try to reach from the trunk it's pretty far in.
865Cam (02-19-2022)
Old 11-24-2014, 07:30 PM
NYC-Style's Avatar
Corvette/2017 E-300
You have to lower the backseats to reveal the other two anchor loops...it took about an hour before I figured it out!!
Old 11-24-2014, 07:52 PM
StanNH's Avatar
I didn't look behind the rear seats, but I'll check that out tomorrow. Assuming they're there, that still won't help in securing all four hooks on the net ... they're just too far apart from the rear of the trunk floor where the other two anchor points are.
I guess the question still remains ... has anyone actually been able to secure the cargo net in the trunk?
I can understand some of the really high tech stuff being not ready for prime time, but a cargo net?
Old 11-24-2014, 07:55 PM
Leslielp's Avatar
Mercedes trunks have that one thing in common the placement of those four tie down hooks.
Old 11-24-2014, 08:30 PM
crxsnow's Avatar
I've been able to hook the cargo net on all the hooks but it is very tight. I had to pull on the last cargo net hook pretty hard to get it even close to the last tie down. And that was with nothing under the cargo net.
Old 11-24-2014, 09:24 PM
joshg1001's Avatar
2017 E300
on my older C, the hooks are concealed under the map (if you can even call it a mat) but there are slots built into the carpet where you can push them through
Old 11-24-2014, 10:26 PM
NYC-Style's Avatar
Corvette/2017 E-300
Here you go this should help....
Passat774 (06-17-2017)
Old 11-24-2014, 11:03 PM
Leslielp's Avatar
Great photo.
So the idea is to put your stuff on the top or squeezed under the net?
Old 11-24-2014, 11:07 PM
PeteInGilroy's Avatar
'18 GLC 300 4M/Air Suspension
Originally Posted by Leslielp
Great photo.
So where do the groceries go? Under the net?
Old 11-24-2014, 11:13 PM
joshg1001's Avatar
2017 E300
yes under the net so they don't slide around
Old 11-24-2014, 11:33 PM
I think Lexus has a better idea: they have an envelope/net that stretches from side to side at the rearmost part of the trunk. If you want to put a set of golf clubs in the trunk, you just unfasten one uppermost loop at the top and the net falls to the mat. Four grocery bags fit nicely and nothing gets crushed.
I thought I saw, in the MB ads, they have some box like storage that somehow rests on the trunk floor and is secured by the deck lid.
Old 11-24-2014, 11:35 PM
joshg1001's Avatar
2017 E300
I have used those Lexus nets before and sure they are great but its much more limited in space. Then, in my Lexus SUV, we have a floor net just like this and its actually really great. It doesn't work with small things obviously but the net is tight enough where even large food containers/take out doesn't slide.
you are thinking about the Comfort box, found here
http://www.mbusa.com/mercedes/access...:A001986417110
Old 11-24-2014, 11:39 PM
Angry
OK, sounds good...can't wait to get my car. Talked to the salesman today, and it looks like it should be delivered the end of January. It's going to be a long two months!
Old 11-24-2014, 11:41 PM
joshg1001's Avatar
2017 E300
omg this comfort box is brilliant
Old 11-24-2014, 11:47 PM
[QUOTE=joshg1001;6242044]omg this comfort box is brilliant
You are right...I'll definitely be getting that. Makes more sense than the net. I guess you can have both!
Old 11-25-2014, 12:05 AM
c4004matic's Avatar
17 E43; 21 GLS580
[QUOTE=PeteInGilroy;6242051]
I considired the box, but decided against it. From the looks of it takes a big chunk of trunk space all the time. Without it large suitcases badly fit, with it in place it becomes impossible. Unless its easily removable, I'm not getting it. Anyone know how easy its to remove the whole thing?
Quick Reply: Anyone figure out how to attach the cargo net?
