Excessive Front Tires Wear
Old 11-16-2015, 10:14 PM
6G Schnell's Avatar
Trek Bike
Less than 10k miles, rear tires are good, but front will need replacement soon. Is this typical for c300 4matic?
Old 11-17-2015, 09:38 AM
MASSC450's Avatar
2016 C450 AMG
19" Summer tires, right? Does it get cold in your neck of the woods?
Old 11-17-2015, 10:58 AM
jakc's Avatar
2016 C300
That was the case for me even in a RWD C63. 15k miles and the rear still had room to go but the front was just worn. Also unevenly because they were under inflated during the winter months.
Old 11-17-2015, 02:34 PM
mikbar2's Avatar
2015 C300, 2015 F-350 Platinum, 1969 Mach 1 428cj, 2007 Roadking
2015 C300 4matic with over 11,000 miles and all tires still in great shape.
Old 11-17-2015, 03:18 PM
supersky3k's Avatar
2015 Mercedes C400
what brand is it? Is it pirelli p zero summer tires?
Old 11-17-2015, 04:26 PM
topsider's Avatar
2015 C300 Sport 4MATIC
those look like the continental summers
Old 11-17-2015, 11:15 PM
6G Schnell's Avatar
Trek Bike
Yes, Continental 19" summer tires
I have the same tires on my E63 and at 15k miles they look much better....
Old 11-20-2015, 03:36 PM
parkwood's Avatar
EQC 4matic AMG line Premium Plus replacing S213 220d 4matic with airmatic
Just swapped my summer tyres for winters. The car came with Hankook ventus s1 evo2 tyres been fine in use no complaints. But i am surprised at the degree of wear the tread is 5.8mm so i suspect they will need replacing after next summer. So far the car has only covered 9600k about 6500 miles so they are either very soft or the c is hard on its tyres.....it is a 250 diesel 4matic estate.
I had a glk 4matic 220 diesel previously and the summer tyres covered 22 to 24000 miles and still had 5+mm of tread left when i disposed of the car. That was fitted with continentals premium contact 3. The e class rwd i had needed new tyres around 18000 looks like thec will eat its tyres in the same way. Need to budget!
Old 11-29-2015, 04:57 PM
Stupidnewbie's Avatar
C400
I'm seeing outer shoulder wear on my C400 with Pirelli RF's after 8500 miles of rather mundane driving. I'm going to bring it up to the dealership but I won't hold my breath for them to do anything. I think I'm going to dump the runflats when it comes time.
Old 01-29-2016, 06:11 PM
neweramike's Avatar
2020 GLC 300 4-Matic
I am having the same problem. I talked to my service advisor today and he says that's common for the tires on the C-class to wear fast. I looked at him like he was crazy. I said I have only had the car a year and I need tires! They quoted me over $1100 for tires + $150 to install.
Old 01-29-2016, 10:03 PM
6G Schnell's Avatar
Trek Bike
The same problem?
Can you clarify what does it mean "the same...": front tires wear out faster on the outer shoulder?
If yes, then something is wrong with the front wheel alignment...
Old 02-02-2016, 01:20 AM
SPONSOR
K-Mac's Avatar
Mercedes-Benz CLK 550
THERE IS ONLY FRONT AND REAR TOE ADJUSTMENT OEM!
FOR THE W205 WE SAW THE NEED TO MANUFACTURE AND REINSTATE FROM THE EARLY 90’S PRECISELY ADJUSTABLE (SINGLE WRENCH, ON CAR) FRONT CAMBER AND CASTER AND REAR CAMBER (WITH EXTRA TOE) KITS.
WITH K-MAC THE OFTEN HEARD REASSURING STATEMENT – “FULL FRONT AND REAR WHEEL ALIGNMENT” AGAIN MEANS WHAT IT SAYS!
CAMBER – Allows to actually change the tire contact angle, improving wear/ traction/ understeer/ oversteer
CASTER – Resolves steering pull, increases steering response. With better turn in and high speed directional control, along with improved anti dive/lift under brake and acceleration.
No more ongoing trips to dealers or alignment shops or constantly changing tire brands. A result of worn bushes, altering vehicle height, fitting wide profile tires/wheels, load carrying or because of curb knock damage.
ADDED BONUS IS THESE 4 FRONT AND REAR K-MAC ADJUSTABLE BUSHINGS also replace the highest wearing suspension bushings at the same time - with twice the load bearing area of OEM. Yet still 2 axis/self aligning without the use of air voids allowing also improved brake and steering response.
For the front (only) – there are available fluted Camber bolts. But these are inaccurate (one only position) bolts offering a minimal .3 of one degree (1/8” / 3mm) and require labour intensive disassembly each time.
While the K-MAC unique patented design provides up to 4 times this adjustment range. With the design breakthrough of eliminating the time consuming need to remove bushings each time an alignment setting needs to be changed.
Instead precise single wrench adjustment capability – on car, accurately (under load) direct on alignment rack!
FOR THE REAR SIMILAR KITSProviding Camber also for the 1st time for more even tire wear/traction. Again these 2 inner lower arm bushings are the highest wearing. Bush extraction tool included allowing bushes to be replaced on car. Rear kit also includes importantly extra Toe adjustment bushes to compensate for the new Camber facility.
NOTE – you can purchase adjustable upper Camber arms for the rear, but difficult to fit, access and to reduce inner edge tire wear unlike K-MAC lower arm bushings – these arms need to adjust top of tire outwards which reduces all important clearance to outer fender.
Front W205 Camber and Caster adjustable bushes $480
Rear W205 Camber (and extra Toe) adjustable bushes $480
Delivery price for MB World members USA/Canada is $30 one kit or $40 front and rear.
Payment can be made by PayPal, Visa, or MasterCard.
See link for latest 2016 catalog http://K-Mac.com/mercedes/
Old 02-03-2016, 11:24 AM
jtsatl's Avatar
I have the same problem. At about 5,000 miles the outer edges of the tires were cupped, which increases road noise. The dealer replaced them with no explanation of anything being wrong. Now 4,000 miles later the new ones are cupped as well. I have 18 inch wheel with Continental rft. 4matic
Old 02-03-2016, 12:40 PM
CO2010's Avatar
2015 C300 RWD Sport Premium
I already replaced one of my front 19' Pirelli's due to a nail but my other one with only 7500 miles has to be replaced due to excessive wear
Old 02-14-2016, 11:09 PM
C400
My fronts are just about wiped at 11,500 miles. Well, the outer shoulders are. I already took it in and they did a front-end alignment but wouldn't do anything about tires. I think I'll probably go to non run-flats and plan to use my AAA service if I get a flat.
Old 02-17-2016, 05:44 PM
madandyd's Avatar
C220 Sport (2014 model)
My factory fitted Continental lasted 20K miles on the rear (about 7 months) and just on 40K miles on the front. The rears were replaced with Michelin and have now done 25K miles with around 4.5mm tread left on them; the front are now also Michelin with 5K miles and still look fresh!
Old 02-18-2016, 12:46 AM
C400
I'm assuming your car isn't 4matic?
Old 02-18-2016, 03:24 AM
116Benz's Avatar
2014 C250 AMG + 2013 E220 CDi + 1994 E220
21'000 km on Pirelli P Zero fronts, replaced due to a savage pothole (figured replace both fronts at the same time) warping the sidewall.
Funny thing, the same place I was getting replacement tyres, an A45 AMG was having the same thing done from the same pothole on the same road.
Old 02-18-2016, 11:59 AM
ashish_patel's Avatar
2015 C400
I had the same problem with my Continental Sport Contact SSR tires. I contacted Continental and they offered me 50% off of my next set of front tires. Maybe you could try that and see what they offer you.
Old 02-18-2016, 02:14 PM
madandyd's Avatar
RWD
Old 09-17-2016, 05:10 AM
nimrod01's Avatar
Mercedes C220 Blutec Sport Saloon Tiptronic Auto (W205)
Excessive front Tyre wear on outer edge
I bought my car C 220 Bluetec Sport under the Mercedes Used car warranty scheme with c.7500 miles on the clock and as part of my pre-sales checklist, I got the dealer to photograph the undersides of the car (both front and rear) whilst jacked up on their workshop ramp prior to me actually taking delivery. The dealer was 120 miles from home and I essentially wanted to be sure that no damage had been occasioned to the underside by previous (1 owner) before committing to buy. The car is well within manufacturer's warranty period. Satisfied that no damage was apparent, I bought the car, but on taking delivery I did notice that the outside edge of both front tyres showed noticeable wear at relative low mileage. I queried this matter with the dealer who shrugged off my concern suggesting that it might have been caused by over use of the 'Active Park Assist' feature fitted to my car. I monitored this wear closely and after a few months (approx 2,500 miles later) I noticed the wear was evidently increasing although I had only ever used 'Active Park Assist' twice, just to check it worked OK. I reported my concern to my local Mercedes Benz dealer who said that tyre wear was not covered by warranty as such wear is most likely caused by driver error, ie. knocking the steering geometry out of alignment and I'd have to bear the cost of having steering alignment checked and re-adjusted myself. So I then looked more closely to the photos as originally taken by the dealer who sold me the car and although not specifically focussed on the front wheels, they did show the wear present, as described on both front tyres. Armed with this Mercedes did agree to undertake a steering alignment test on my car. But importantly the dealer referred to 'new toe-in values', as issued by MB engineers at Bremen to be implemented by Mercedes Workshops after 04/11/16 and they confirmed that my car had been adjusted according to these new values. This to me suggests that Mercedes are clearly aware of the problem of excessive front tyre wear and have made some attempt to rectify the issue. However, as ever time will tell.
Old 09-17-2016, 05:22 AM
nimrod01's Avatar
I have just had my Annual 'B' Service carried out and the condition of my front and rear tyres featured as an 'advisory comment' that although well within legal requirements, tyre wear is evident. As I take particular care when driving not to exert extreme braking or steering pressures, I am concerned about this apparent 'excessive' tyre wear issue with the C class.
Old 09-17-2016, 09:09 AM
MASSC450's Avatar
2016 C450 AMG
Originally Posted by nimrod01
I bought my car C 220 Bluetec Sport under the Mercedes Used car warranty scheme with c.7500 miles on the clock and as part of my pre-sales checklist, ...I queried this matter with the dealer who shrugged off my concern suggesting that it might have been caused by over use of the 'Active Park Assist' feature fitted to my car. I monitored this wear closely and after a few months (approx 2,500 miles later) I noticed the wear was evidently increasing although I had only ever used 'Active Park Assist' twice, just to check it worked OK. I reported my concern to my local Mercedes Benz dealer who said that tyre wear was not covered by warranty as such wear is most likely caused by driver error, ie. knocking the steering geometry out of alignment and I'd have to bear the cost of having steering alignment checked and re-adjusted myself. So I then looked more closely to the photos as originally taken by the dealer who sold me the car and although not specifically focussed on the front wheels, they did show the wear present, as described on both front tyres. Armed with this Mercedes did agree to undertake a steering alignment test on my car. But importantly the dealer referred to 'new toe-in values', as issued by MB engineers at Bremen to be implemented by Mercedes Workshops after 04/11/16 and they confirmed that my car had been adjusted according to these new values. This to me suggests that Mercedes are clearly aware of the problem of excessive front tyre wear and have made some attempt to rectify the issue. However, as ever time will tell.
Thanks for the info on the alignment changes made by Mercedes. What size wheels/tires are you running on your car?
I ask because I ran the 18" AMG wheels/all-season tires on my old 2015 C300 Sport 4matic...put 6,000 miles on them, and the tires front and back still looked brand new when I traded it in for my 2016 C450. Now on my 19" AMG performance tires, I started to notice slight wear on the front tire outside edges after only a couple thousand miles...which would be expected from a performance tire.
Old 09-17-2016, 12:03 PM
nimrod01's Avatar
The tyres fitted are 17" Continental ContactSport 225/50 R17
Old 09-17-2016, 12:54 PM
bowler900's Avatar
C220 Bluetec
I currently have over 36000 on the fronts of my W205 but changed the rears at less than 21000, admittedly I do carry around 150lb of kit in the boot/trunk at all times.
Quick Reply: Excessive Front Tires Wear
