More NOX sensor problems
Old Dec 8, 2015 | 10:21 PM
DBOC205's Avatar
W205 C250BT
About 3 weeks ago I had the Check Engine Light come one. My OBD scan revealed a P229F - NOx Sensor Circuit Range/Performance (Bank 1 Sensor 2)
They replaced the NOx sensor in the Cat converter apparently and reset the car. Today I get ECL again..
P229E - NOx Sensor Circuit (Bank 1 Sensor 2)
P22A0 - NOx Sensor Circuit Low (Bank 1 Sensor 2)
I can't believe it. What's going on there - is it likely that the same sensor has failed again, but thrown different codes? Or is it possible that they just pulled the sensor out - tested it - found no issues and put the same one back in again?
Guess it's time for yet another warranty booking
Old Dec 10, 2015 | 03:13 AM
DBOC205's Avatar
W205 C250BT
Wow.. my run of bad luck with the "Best or nothing" brand continues. Took the car in to get checked today and after 2 hours they were still unsure of exact issue so they gave me a courtesy vehicle to take home. Just found out that there's a fault in the wiring harness to the NOx sensor and needs to be replaced.
What's frustrating is that the part isn't in Australia anywhere - closest place they were able to source it was Singapore. I'm probably looking at 2 weeks before I get the car back.
Well .. this officially makes my new C Class the most unreliable car I've ever owned.
Old Dec 18, 2015 | 06:34 PM
DBOC205's Avatar
W205 C250BT
Got my car back early (which was nice).. but I thought I'd post an update to hopefully help others who encounter similar issues:
1) If you get NOx sensor failures - get them to check the aircon drainage paths. Turns out what was happening on mine was that the factory didn't fit the air-conditioning drain properly and water was accumulating in a wiring harness. The resulting damage was that a connector on the harness corroded requiring a patch harness to be fitted.
2) On an unrelated problem, I can absolutely confirm that a software update to the keyless module fixes the the infamous keyless go chirping cricket issue. When I mentioned it to the dealer he knew about the noise but was doubtful that a software update would fix it. Anyway - it worked.
Happy motoring over Xmas and New Year everyone.
Old May 12, 2022 | 05:46 AM
zariben's Avatar
S205 220d
Hi, I receive an error P229E - NOx Sensor Circuit (Bank 1 Sensor 2). Where is located this wiring harness?
