2015 c300 sport+ poping sound changing gears
2015 C300 w/ sport pack has the pop sound.
2017 C300 loaner w/o sport pack didn't or very very minor pops..
This made the AMG Performance Exhaust on my C43 even worth the value. LOL
STOP VEHICLE LEAVE ENGINE RUNNING
I have experimented two car C250 (W205) and GLC 250 with regards to Voltages and Amps, as I have similar warning, its good that I have identical car where one have problem where you can compare the alternator or battery performance , here is the details. both car Manufacture 2066 but I bought 2017 for C250 and 2018 for GLC 250.
The C250(W205) had Stop/Leave engine running for +/- 2 weeks, however engine starting system is Ok, while GLC 250 does not have this message.
1. Preparation display Voltage & amps
a. Switch ignition position 1
b. Select display where trip top/ total trip bottom
c. Press phone (Call) then (within split seconds) OK (hold 5 secs)
d. then go to vehicle data /where it shows voltage (UB:12.4, IB -15A, TB: 40oC etc) this would be Battery Voltage, the charge rate (+ is charging – is discharge), then TB is Temp of battery.
2. GLC 250 Testing (from internal data)
When the ignition on, the display is UB:12.4, IB -15A, TB: 40oC
After I started the car, the Batt drop to 11.4 Volt UB, Amp drop t0 -200 Amp IB (split second), -30, -20 then after 10 seconds idle the volt reading 14.8Volts and charging rates 50-30 Amps. There is no message / NORMAL.
3. C250 (W205) (from internal data)
When the ignition on, the display is UB:12.3, IB -15A, TB: 37oC
After I started the car, the Batt drop to 10.6 Volt UB, Amp drop t0 -240 Amp (split second), -30, -20 then after 10 seconds idle the volt reading 14.8Volts and charging rates 50, 40,30,20 then goes to 18.8 Amps then the MESSAGE APPEAR.
So I replace with identical VARTA 71 Ah battery where the result is identical with GLC 250.
I was recommended to do computer reset by delaer but this does not requires computer reset and the memory remain ( I assume the backup battery is still good)
I hope this helpful.
I am not sure what is UB, IB & TB stands for, any one ?
you want to see the video (im not sure if this is OK, try to open youtu.be/eTFXjA2xufQ
