Noise from steering
I have a C200 AMG Line in the UK and I've only noticed this today.
Parking up today I moved the steering wheel quite fast and heard a noise come from the front end so once parked I moved the steering wheel from side to side quickly and there is definitly a noticeable noise from the front of the car which can be heard from the inside and out, not sure what it would be but sounds to me like something is loose or there is a bit of play in something to do with the steering. The noise is the same whether the car is on or off.
Does anybody else's car do this or is it something that should be looked at?
I've not noticed any such noise on mine. I do get occasional knocks from the suspension over bad roads (airmatic) which the dealer has looked into and found no issue, it's very rare though and I suspect it's probably just a hose tapping the bulkhead of something as it has to be quite a bad road to reproduce it.
I only noticed it because I was parking and turned the steering wheel quickly in the opposite direction.
I'll try and get a videos of the noise and see if you can hear it.
Dealer just called me up and told me that it needs a new steering rack due to a fault. Not sure if it was a major/dangerous fault they wouldn't really tell me much over the phone.
Service information: rack and pinion clearance
If you turn the steering wheel left / right when the vehicle is stationary, especially without power steering, you may hear a knock. This phenomenon is due to the design and is not a sign of any will or less loud steering.
Are all of the buttons working including steer wheel illumination?
It required only a new steering wheel + coding ?
how much was the total price for this ?
regards
Drop them an e-mail or contact this guy his name is Sam I dealt with him: whatsapp: +6689-227-7756.
Hope this helps.
If you do think there is something wrong and the garage refuses to do anything then I would definitely try a different dealership.
I now have a GLC which I’ve only had for 1 year - it developed a rattle and squeaky suspension.
Took it to the dealership where I bought it from and they refused to acknowledge a problem, took it to a different one and they ended up changing the drop links and both rear shock absorbers under warranty!
