Window not returning to closed position
Old Aug 5, 2016 | 10:29 PM
Needhep's Avatar
2015 Jeep Cherokee , 2004 Mercedes CLK 500 convertiable
I have a 2004 CLK 500 convertible and when I open the door the window will drop a little and go back up when I close the door . Now the passenger side window will not go back up to the closed position when the door is closed. I have to close it from the inside . Any suggestions on what may be wrong or what i can check. Thanks .
Old Aug 5, 2016 | 11:36 PM
PeterUbers's Avatar
Try toggling the door pin and see if that's what's doing it
Old Aug 6, 2016 | 07:47 AM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
You may need to reset the Windows however you will need to ask advice in the correct forum as you've posted in the 2015 C class section.
Old Aug 6, 2016 | 09:37 AM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
Most cars will re-index by holding the window in the closed position, then the down position for a few seconds.
