Tire pressure for C300 4matic
Ford C max , C300 4-matic
Are you folks using the Tire pressures indicated in the sticker by the side door? Mine says 39 psi Front and 45 psi Rear . However the tire pressures as delivered from the dealer was 39 psi all round. What should I use? Tks
The correct pressures are listed under the fuel filler door. The side door shows maximum loads. 39 is fine, but you can also try 36-38 and see how it feels.
1 Post
2015 C300 4matic - W205
It's a mess. Fuel filler door says 36psi at normal load for Front and Rear. Then in smaller print below it says -4psi if driving less then 100mph. So who in the USA is not driving less then 100mph. I like my car but MB is a mess to figure out for both oil and tire pressure.
