Auto High Beams Operation
Old Jan 22, 2017 | 02:00 PM
jherm's Avatar
C63S
I must be missing something regarding operation of the high beam lights. The high beam flash works properly by pulling the combo switch/stalk towards me. When I push the stalk away from me the auto high beam light turns on in the gauge cluster, but the high beams never actually come on. I think the auto high beams turn on and off depending on your surroundings suck as approaching vehicles or a vehicle in front of the car. But I haven't been able to get the high beams to come on in any situation via the auto high beam option even just sitting in a garage.
The high beams obviously work since they turn on via the flashing function. But I haven't been able to turn on and leave on. What am I missing?
Old Jan 22, 2017 | 02:19 PM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Originally Posted by jherm
I must be missing something regarding operation of the high beam lights. The high beam flash works property by pulling the combo switch/stalk towards me. When I push the stalk away from me the auto high beam light turns on in the gauge cluster, but the high beams never actually come on. I think the auto high beams turn on and off depending on your surroundings suck as approaching vehicles or a vehicle in front of the car. But I haven't been able to get the high beams to come on in any situation via the auto high beam option even just sitting in a garage.
auto high beams only work while the car is in motion. Depends on situation.
Old Jan 22, 2017 | 02:26 PM
jherm's Avatar
C63S
Hmmm...well that explains the garage. But I have been in multiple situations while driving where I wanted to put on the high beams and couldn't without having to hold the "flasher" on. I wonder what was causing the high beams to not come on in those situations. I guess I'll just have to keep doing some trial and error testing.
Old Jan 22, 2017 | 02:52 PM
GerritKw's Avatar
C350e
When you are driving in an area where there are street lights or does not activate either. Also it does not work at low speeds.
It usually switches on when you are driving on main roads or highway without any upcoming traffic.
Old Jan 22, 2017 | 04:32 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
If you want manual control of the high beams, turn the main headlight switch to the "ON" position instead of the default "AUTO"
Old Jan 22, 2017 | 05:11 PM
kleinebin's Avatar
W214 AMG Line
Because they are on auto. When you push the lever away from you and it confirms they are active on the display they only turn on when necessary. If you're on a freeway that's well lit they won't turn on however if there are no lights then they will.
As above if you want manual control you need to change your light settings from auto.
Old Jan 22, 2017 | 05:39 PM
sean1.8t's Avatar
c-fo-fiddy
This ^
The auto is nice when you are in the middle of nowhere and it's dark as hell, but the sensor that detects oncoming cars is way too sensitive. If someone's porch light is on it will think it's an oncoming car. I've even had it turn the high beams off because the beams reflected off of a street sign
So around town I just turn the headlights to "ON" and turn the high beams on/off the old fashioned way. Otherwise they would never come on.
Old Jan 22, 2017 | 05:43 PM
jherm's Avatar
C63S
Originally Posted by sean1.8t
This ^
That is exactly what my experience has been. Driving on pretty dark neighborhood streets sparsely populated with dim lights and it wont turn on the high beams. The trigger point is just way off in my experience. As you said, they just never come on if I'm in auto.
Old Jan 22, 2017 | 06:02 PM
GerritKw's Avatar
C350e
You might need to have them adjusted. They seem to be too sensitive. Street signs are ignored by my car. I have the ILS version.
Before i drove a Ford Mondeo with Auto high beam and that worked fine also.
Old Jan 23, 2017 | 03:49 AM
sean1.8t's Avatar
c-fo-fiddy
By "have them adjusted" I assume that you mean "have the dealer adjust them"?
Old Jul 30, 2021 | 11:44 AM
mikefalz's Avatar
2010 Mercedes Benz E550 Coupe
As another member mentioned above, the 'automatic' function of the high beams relies on a minimum speed (ie.... they will not come on when going only 15mph).
Make sure the stalk is pushed into the forward position (small headlight with 'A' will display) When conditions are correct, brights will go on and the blue colored indicator will also display. Find an appropriate road to go somewhere >35mph with no cars coming at you on the opposite side and none in front of you.
In my 2010 E550 they work, on and off, within a second or so each time.
Good luck
Old May 28, 2023 | 03:51 PM
Hundens's Avatar
2014 Jag F-Type vert, 2004 Volvo V70R
RJAutomotive looks to be a real business. And the 200 BPS is much more realistic than what we were seeing previously from an unknown source. For the life of me, I can’t understand why MBUSA doesn’t offer this enhancement now that it is legal in the United States (large part thanks to Toyota).
Old May 28, 2023 | 06:08 PM
BenzNinja's Avatar
Former Vendor
we offer ILS+ for free to our members
50% off + $250 value Golden ticket
https://mbworld.org/forums/c-class-w...a-s-n-1-a.html
