Phone mount, the BEST one yet
Looks like we have the same case. I like how it slides in the cupholder at that exact angle just fine and holds it in there very snug for spirited driving. That might fly off under your feet on a hard right turn?
TL;DR - It's perfect for everyday driving, and if you're at Willow Springs or Laguna Seca I don't think you'll need your phone anyways.
If I get out for a joy ride later this week, I'll throw the GoPro in behind me and check out the limits based speed and G-Force (because why not?).
Note that I did not go any further than (1:17 into video) simply pulling up the front of the center console and feeding my lightning cable through to a hole in the cupholder compartment. Only thing that was difficult was getting the silver trim off in the beginning, seriously thought I was going to break it. When you run the cable, it should go from USB, under the center console doors, then under the silver piece, and from there I go under controls to cupholder, but alternatively, you could have the cable just follow where the ambient lighting would go.
Anyways, yes I did get mine and I would definitely recommend it if you are okay with the lower position!
Man that thing is SOLID when you get it set up right. My notes and recommendation are: - Make sure you get the dock down in there so the 4 spring-loaded notches hold it in place because then you can just pull your phone out and you'll never have to worry about the thing flying around in a turn.
- You really have to work the lightning cable in there so have a flathead screwdriver or something, and make sure you push it up far enough for your case.
- [Optional] Wire an Apple iPhone cable up from center console rather than using a USB in the cigarette lighter if you want to take advantage of the benefits vs. bluetooth. I actually took my center console out having referenced a CATAHA video, which I can no longer find, but this is a good reference as well. https://www.youtube.com/watch?v=g6_HM4zfV50&t=73s. Note that I did not go any further than (1:17 into video) simply pulling up the front of the center console and feeding my lightning cable through to a hole in the cupholder compartment. Only thing that was difficult was getting the silver trim off in the beginning, seriously thought I was going to break it. When you run the cable, it should go from USB, under the center console doors, then under the silver piece, and from there I go under controls to cupholder, but alternatively, you could have the cable just follow where the ambient lighting would go.
Hope this helps and let me know if you have any questions! Here are some (very unprofessional) pictures.
Notice (1) how far down the dock sits to remain secure and (2) how high I have the lightning cable to accommodate the depth of my phone case:
Now I am excited for this. Looks like mine should arrive on the 16th. And thank you for the youtube link. That will be super helpful!!
http://www.kudausa.com/kuda-custom-l...2015-k913.html
I might order the second choice.
Integrates beautifully.
Don't use the screws, tho.
Use 3M trim tape to secure it.
After lurking for a while I decided to contribute with my solution to the best mount for the W205.
to make a long story short, this "CD mount" works amazing in the only trim imperfection I found in the C300 (2015 with a gurgle between gears yo!).
its this one (been using for 4 months now)
https://www.amazon.com/Koomus-Pro-CD...KC3BC8NM85Q5YB
And it looks like this with the iPhone 7 Plus
hope this idea helps someone.
That hurts me to see lol that thing you glued on your screen will not want come out without ugly scars
a
that position exposes your phone to everyone on the road, if you are tempted to change the playing track or gps destination at a red light you might get a ticket.
I have a flat magnet that is less ugly (no arm with ball socket) that I'm thinking on...maybe I'll deal with the phone not being angled toward me or I'll find a mild wedge that I can place between the screen and the magnet. When I experiment with that, I'll let you know if the tape doesn't come off well.As for visibility of the phone to others, I'm not concerned. I can advance a track with one touch on the phone or with my watch and probably with voice.
But I like it. Works well with the smaller screen since you have a huge "dead zone" border. Took me a second to put that together cause at first I was like no way in hell I'd put that on mine as it'd take up probably close to a full inch of the picture
I have followed this thread for a while and wonder how i would fixed the mount, i don't wont any damage tog the interior so i figuered out a holder that slides over the display.
I made a template out of wood and heated and bent the plastic, did 2 tryouts with the lenghts of the legs in front of the display. The finish could be better, maybe i do another when i have the time.
The gap between the aluminum and the Pleather dash fits perfectly
At night seems like the S class split screen with NAV.
Also note, I ran the charger cable under the console trim and it sticks out just at the location of the phone. the cable ran from the rear seat 12v outlet all the way there, so the front console cover can be closed.
The supplied metal plates I just put in the cover of the iPhone without gluing to the actual phone.
Yes I picked this AVB album and Climate screen on purpose.
Top
Front
Bottom
