Phone mount, the BEST one yet
After lurking for a while I decided to contribute with my solution to the best mount for the W205.
to make a long story short, this "CD mount" works amazing in the only trim imperfection I found in the C300 (2015 with a gurgle between gears yo!).
its this one (been using for 4 months now)
And it looks like this with the iPhone 7 Plus
The gap between the aluminum and the Pleather dash fits perfectly
At night seems like the S class split screen with NAV.
Also note, I ran the charger cable under the console trim and it sticks out just at the location of the phone. the cable ran from the rear seat 12v outlet all the way there, so the front console cover can be closed.
The supplied metal plates I just put in the cover of the iPhone without gluing to the actual phone.
Yes I picked this AVB album and Climate screen on purpose.
I've used magnetic mounts before and haven't had an issue but it was more expensive so may have been stronger. This seems like a bargain at 20 bucks. Good reviews on amazon
Huge potholes thanks to City of Philadelphia, stayed on even after I dropped from two metal plates to 1.
I know the ones you are referring to, this thing is a very strong magnet.
I did check to see if there is "long term damage", but no, it just goes back to its original shape. Press the clamp all the way, push into the wedge, and let go.
While fishing around, I realized that the gap on the side of the glove compartment door is a perfect gap. A little further to the right than most want, but I don't look at my phone very often anyways.
(not my car)
