Pinging/Knocking/Detonation? Sounds like rocks in the engine on acceleration..
Old May 26, 2017 | 10:54 AM
Hapa88's Avatar
2017 C300 Coupe (C205)
Originally Posted by Hapa88
Over a 20 minute drive of me constantly hammering it off the line or hard passing, I only experienced it once when I drove it.
I'll quadruple check with her to make sure she's using Premium gas, because that was my initial thought as well.
Originally Posted by cenzo86
Can you take a video so I can hear some audio of the sound? Most modern direct injection engines do have a very constant ticking, like a sewing machine during idle. The ticking is from the high pressure injectors. Your engine is designed to run on premium, but if lower octane is detected, the car's ECU will go into knock protection mode, lowering power output to prevent detonation. If you are experiencing detonation your CEL will go on.
As I said before, it happened once during a 20 minute drive of me hammering it off the line and passing trying to replicate it. I probably could get a video but it likely wouldn't happen for another 2-3 months when I get the chance to head back out there and set it up.
I've had intermittent knock before on OBDII cars and I've only seen the CEL come on when it happens for an extended period of time. In our case, it happens for a period of less than 2 seconds and goes away as soon as you let up on the gas and get back on it. Currently there is no CEL on her car resulting from this.
Old Nov 3, 2021 | 08:15 PM
Sugar_Mouth's Avatar
2014 E63S, 2018 GLC 300
I am experiencing the exact same issue with a 2018 GLC 300. Did you find the cause or solution?
Old Jun 7, 2023 | 11:44 AM
W205GOD's Avatar
2018 c300 AMG SPORT PACKAGE
2018 c300 knocking sound no check engine
please help me out
File Type: mov
Old Jun 9, 2023 | 01:40 PM
secouture's Avatar
CLA 250 ALL 4
Same issue!
Originally Posted by W205GOD
please help me out
Hi there, I've been having a very similar issue with my 2014 CLA250. I've taken it to a mechanic I've trusted for years and they didn't seem very concerned and didn't hear what I was referring to but I'm up tight about my car and would prefer it last forever. Wondering if you've found the culprit? Appreciate any feedback! Thanks!
