Brake Pad and Door Issues
Old Jun 13, 2017 | 09:49 PM
Standingoten's Avatar
C450
3500 miles on my C450 that I got in Nov 2016.
Its been making loud screeching noises when braking especially now that it's warmer out. Dealer is replacing brake pads.
The bigger issue I had was my driver door not opening. I pull the interior door lever and the door doesn't open. I have to push really hard to get out and even then sometimes I just can't. So I climb into my passenger seat and use that door to get out. Turns out the window trim warped and caused this.
These two two issues along with the rattles and door seals falling off...I'm quite disappointed!
Old Jun 13, 2017 | 09:57 PM
dieseldoc's Avatar
2022 E350 Diamond White Metallic, 2016 GLC300 Dakota Brown Metallic
Squeezing brakes are a common problem. I have had them with my GLC. stuck door sounds like a bad mechanism or faulty release. Time for a trip back to dealer.
Old Jun 13, 2017 | 10:13 PM
auditoamg's Avatar
C63s
Same issues with brake pads and window seals... Just started with sunroof, as well. At dealer for all, now.
