How can I remove this scratch?
I noticed the other day there is a minor scratch in the door trim. Does anyone know how to remove this?
I don't have kids nor have a lot of passengers but found that scratch while I was cleaning it...
Help me out
If you scrape a fingernail over it can you feel it catch on the defect? If so, you'll probably have to live with it. If not, try a little polishing compound on a clean cloth and work it in the same direction as the grain in the trim.
Be careful with polishing. This highly likely results in a more glossy area than it's surrounding. I would rather have the scratch then.
Update
My purchasing and servicing dealer
was thankful enough to replace the door trim and
the door handle with a peeled paint at the other side.
Really random that it happened on the rear because
I rarely even open the back seat...
noticed that while detailing the car.
Issue solved.
MB is willing to cover excessive cosmetic wear under warranty.
Issue solved.
