How can I check the condition of rear shocks?
Hi fellow owners.
From a few days ago I notice my car would sag a little more than it used to when loaded up with one or two people in the back. How can I check the condition of the rear shocks? I don't have that much time for a while to go to the dealer. Thanks in advance. |
Push down hard with all your weight on the rear and let go. It should instantly bounce right back. Without AirMatic's load leveling ability, adding more weight in passengers and cargo will compress the steel suspension a bit. AirMatic cars should compensate. (They'll actually compensate for the weight of fuel ).
Originally Posted by Mike5215
(Post 7240994)
My car does bounce up right away. but still think my car does get lower than before when loaded up. Can this be a placebo affect? lol Is it even possible for car to be lower if the shocks are good? |
(Post 7240994)
(Normal) https://cimg8.ibsrv.net/gimg/www.mbw...56943581f.jpegWhen loaded... looks too low to me for the weight... and even compare to past occasions. This is the condition for reference. |
Hard to tell. The whole car looks low for a base (non Sport) suspension. I guess go by a dealers lot and compare.
shocks
Originally Posted by fantasy521
(Post 7240955)
Hi fellow owners.
From a few days ago I notice my car would sag a little more than it used to when loaded up with one or two people in the back. How can I check the condition of the rear shocks? I don't have that much time for a while to go to the dealer. Thanks in advance. More likely the two that you put in the back have gained some weight.:) |
Originally Posted by Piperkid
(Post 7241033)
Shocks do not hold a car up - the springs do. Shocks are purely to dampen up and down movement of the wheel, so your shocks are not the issue.
More likely the two that you put in the back have gained some weight.:) Based on your observation from my pic. If my car bounces right. Do you think the car is normal? (height) Mike at the top tells me that my car is low for having a base suspension. |
(Post 7241029)
Car height
(Post 7241054)
Oh I see..
Based on your observation from my pic. If my car bounces right. Do you think the car is normal? (height) Mike at the top tells me that my car is low for having a base suspension. A picture from the side at seat height might show how level the car sits. |
(Post 7241069)
looks correct to me but hard to tell from those pictures.
A picture from the side at seat height might show how level the car sits. Last question based on the top pic does the rear and the front seem to sit even? |
We won't be able to tell from the pics. Different angles, don't know what height the camera is at, etc.
You can easily use a tape measure and measure the distance from the ground or top of the tire to the fender. Make sure to do this on flat ground. Then go to a dealer and compare measurements. Also, what year is it and mileage? |
(Post 7241003)
Thanks for the reply.
My car does bounce up right away. but still think my car does get lower than before when loaded up. Can this be a placebo affect? lol Is it even possible for car to be lower if the shocks are good? Ernie |
