retrofit rotating tweeters (burmester copy)
2015 C300 4Matic Sport
PRO TIP: don't be stupid like me and spend hours trying to get the door panels back on with the rubber window glass seal attached.
Turns out the top window glass seal slides out of the door panel and can clip back together with some pressure after you have it aligned correctly.
#32
it's plug and play.
1. Disconnect #6 connector from door controller and plug it into the harness, then plug the harness into #6 port.
2. Disconnect tweeter 2 pin cable, plug into Y harness cable to new 3d tweeter.
3. Spend 5 hours trying to put left door panel back on with speaker installed. (realize your mistake)
4. Spend only 40 minutes on entire right door speaker install.
#33
Has anyone gotten the mid speaker LED yet? I have a E450 Cabriolet, with the tweeter next to the mid speaker and not on the sail panel, so tweeters wont work for me. The mid's are another question.
#36
Finally installed the new tweeters. They look and sound awesome! Fitment was ok. Benzdude, how was your fitment on each door? My drivers side went in fine but passenger, I struggled to fit the thing in there. In any case, money well spent! Will post pics later...
#37
I had to first reroute the existing mirror cables (try not to bend the fiber optic cables) to the left and right sides, and then mini zip tie them in place. This made the install easier.
Congrats.
#39
Yeah I tried that too. Passenger side was a PITA to fit in but it's there. I'll probably take the door panel off in warmer weather in late spring and reroute the cables like you did. Driver side fits perfect tho.
#42
Cranberry red leather. Thanks! One of the main reasons I bought the car. It’s a 2015.
MBSebas87 (01-26-2019)
#44
Benzdude ...thanks man. Is it just me or the tweeters actually sound much better than the OEM? Just noticing better sound quality especially in sorroud mode.
#45
You should play a good tweeter song and compare them with the back tweeters. Hop in back, stick your ear close.
#47
Need help with the burmuster tweeters lights
GUYS HI i need help i got my 3d tweeters but i cant get it to light
my tweeters is for the W205 C180 have an extra 4 pin plug i have no idea were to connect this plug
i got the tweeters to work and every thing motor working fine but no light ,
#48
Did the seller confirm your car year, model and number of ambient package colors, if any? Not all aftermarket 3d tweeter kits are the same.
Is your car a 2015 w205 with factory 3 color ambient?
mabadr (06-10-2019)
#50
i confirmed with them the model
i cant find a place to plug this extra 4 pins
