New tire 19 inch
Old Jun 14, 2019 | 06:01 AM
Mikael10's Avatar
W205 c220d
New tire 19 inch
Hello,
Just got New tire on my 19 inch rim.
Front rim 8.5
Rear rim 9.5
The new tires are:
Front 235/40/19
Dear 275/30/19
Is that ok ?
I Think the front tire looks very big
Old Jun 14, 2019 | 09:01 AM
CJG's Avatar
CJG
2016 C300 4MATIC
I think it should only be 5 difference. Not 10. As in 35 and 40. Not 30 and 40.
Old Jun 14, 2019 | 09:23 AM
Mikael10's Avatar
W205 c220d
The wheelshop says is it normal
Old Jun 14, 2019 | 09:38 AM
CJG's Avatar
CJG
2016 C300 4MATIC
Mercedes says otherwise:
  1. 225/40R19 | 93Y
  2. 255/35R19 | 96Y
If you're so sure why are you even asking?
Old Jun 14, 2019 | 09:45 AM
Mikael10's Avatar
W205 c220d
Because I do not trust the shop
Old Jun 14, 2019 | 10:05 AM
CJG's Avatar
CJG
2016 C300 4MATIC
LOL. Then why did you buy them without checking elsewhere first?
Old Jun 14, 2019 | 10:28 AM
alexasa's Avatar
c
also an uninformed response (because that measurement is only a ratio of the width of the tire - so a staggered set-up could easily require a difference in ratio greater than 5).
Tire diameter should be within 3% of stock. You are increasing the front diameter and decreasing the rear. Both are within spec of their respective corners but from front to rear they have greater difference than that 3%
This would not only look weird as hell but could also trip internal sensors and cause issues.
What size wheels? anything 9.5 width and below - just spec a 265/35 for the rear and stay with the front at 235/40
Old Jun 14, 2019 | 10:42 AM
Mikael10's Avatar
W205 c220d
So the wheelshop has made a mistake ?
Thanks you so much for the help
Old Jun 14, 2019 | 02:53 PM
CJG's Avatar
CJG
2016 C300 4MATIC
Say what? The numbers I listed are the stock tire sizes per Mercedes. I'd say that's informed.
