W205 Zito 20in Wheels Rubbing Problem
Old Aug 27, 2019 | 12:29 AM
Kelvin Susanto's Avatar
W205
Hi all,
recently I installed H&R Springs onto my W205, together attached the new 20" Rims ZITO ZS05 gunmetal 8.5 Front, 10 Rear. My tires spec are 245/35 Front and 275/30 Rear.
When cruising at 50-60km/h the front left tyre is rubbing the fender, as well as the rear tyre when I drive towards an incline road like multi-storey car park. Weird that the right hand side fitment are a little bit tucked in and no rubbing problem at all.
I have not spoor my car but I found out that the front camber can be adjusted while rear camber is fixed. To be able to get the rear camber to be adjusted I need to buy this, checked online and it is available in my local market:
http://www.hardrace.com/Product_detail.asp?id=3496
Now what I want to discuss with you, which one suits better:
1. H&R Spring + Adjusting Front Camber to tuck in a bit + Installing Rear Camber Kit to tuck in the left rear setup. (I just need to invest more on the rear camber kit).
2. Sell the H&R Spring, forget the rear camber kit by HardRace, buy BC Coilover instead to play with the ride height and stiffness of the suspension to avoid vertical travel of the shock absorber while driving on rough terrain (generally more expensive but the car will be more tune-able).
I need your suggestions, meanwhile I am posting my car setup last weekend. I changed the H&R spring yesterday to reduce rubbing because my wife also drive this car for grocery shopping etc. Meanwhile I am looking for solutions to this problem.
Any comments and suggestions would be much appreciated. Sorry for my English.
Old Aug 27, 2019 | 07:58 AM
alexasa's Avatar
c
where are you rubbing? cause i can't imagine it's anywhere to be concerned. probably just a fender liner or inner fender lip
you chose the wrong tires - they are too tall/diameter too large compared to stock (the rear is okay but front is too tall)
