W205 Static LED Headlights - Yellow Hue
Old May 28, 2020 | 12:01 PM
Kush Desai's Avatar
2016 C300 4Matic
Exclamation W205 Static LED Headlights - Yellow Hue
Hello yall,
I've been searching and searching forums to figure out if this has been brought up ever before but I couldnt find anything.
I've been noticing the color of my headlights becoming more and more yellow (See pictures, Passenger side headlight). I've taken it to the dealers once before asking them if they would fix it, I was told they wouldnt do anything until the actual LED is blown out, mind you the color wasnt as yellow as it is today. They also documented it in the history report.
I'm here to see if anyone else had this happen with their Static LED Headlights. What did yall do? How did you fix it, if you did?
I'm planning on taking it over to the dealers once again before my factory expires next month to see and hope for them to fix this.
Also, for Static LED Headlights, if there even a possible way to change the LED itself at home/by yourself? Can you even access it? If so, HOW?!
TIA!!!
Attached Thumbnails W205 Static LED Headlights - Yellow Hue-1.jpg   W205 Static LED Headlights - Yellow Hue-2.jpg   W205 Static LED Headlights - Yellow Hue-3.jpg   W205 Static LED Headlights - Yellow Hue-4.jpg
Old May 28, 2020 | 04:32 PM
decorily's Avatar
GLC 300d 4matic
Can't help you really ...but there is certainly some thread here about 'yellowing ' LEDs , ( LEDs on door handles specifically ) but as far as I can recall, according to the thread, it is a sign of a failing LED and has been blamed on poor quality bulbs!
