Help. Advice on Which OBD2 Scanner 2017 C63AMG (2020)
Old Jun 17, 2020 | 11:51 PM
TexasBenzBandit's Avatar
2017 AMG C63, 2001 C5 Corvette
Want an OBD2 Scanner for my 2017 C63AMG.
I researched online and some in the forums but it’s 2020 and WHAT are a Few Options that Work??
REASON I’m wanting it now. Just Failed Inspection and have 15 days to TRY again and instead of guessing if car is cycled, I’d like to use the OBD2 to monitor sensors so I KNOW when they are ALL ON and then I’ll go get it inspected.
Also, I do Have a Eurocharged Stage II Tune from Jerry and an AWE SwithPath Exhaust.So no headers or cats removed etc. Basically just a Tune.
Failed Test due to the following:
1. O2 Sensor NOT READY
2. Heated O2 NOT READY
A few ones I looked at were:
-Autel AutoLink A519 OBD2 $59.99
-BlueDriver LSB2 Bluetooth Pro OBDII Scan Tool for iPhone $99.95
-FOXWELL NT6301 $66.49
-ANCEL AD410 $44.99
Want to make sure they Work and can Clear Codes and CEL and not just Read them.
I bought a Bluetooth VEEPEAK with OBD FUSION App and COULD NOT get it to connect. It did 1 time for a minute but then never again. Tried dozens of times.
Thanks Y’all!!!
Old Jun 18, 2020 | 12:59 AM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
Hello TexasBenzBandit. Are you in the Houston area?? If you are, I invite you to stop by my shop. I can show you the Xentry Passthru software in action using the Tactrix device. You might consider getting it. Let me know.
Old Jun 18, 2020 | 01:23 AM
No, DFW.
Old Jun 18, 2020 | 09:34 AM
irondad's Avatar
W205, X253, C190, W213,
Spend a little more and get either the Foxwell NT520 or the iCarsoft MBII. I've had both and prefer the former which I have now.
Old Jun 19, 2020 | 04:21 AM
So you like the Foxwell better?
