W205 7spd Long 1st Gear
Old Jul 12, 2020 | 09:39 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Pretty sure they've started in 2nd gear in comfort mode for all 7 speed transmissions. This isn't new to the w205, the w204 has it. Sport starts in first.
Old Jul 12, 2020 | 10:08 PM
Bmarcinczyk14's Avatar
2016 C300 w/ sport package
As stated before, my 2016 w205 definitely starts in 1st gear from a stop no matter what mode you're in.
Old Jul 12, 2020 | 10:30 PM
Mikey53's Avatar
Veteran: Air Force
2016 C300 4Matic traded in for a 2022 E450 Coupe
from a dead stop, mine starts in 1st. 2016 with 7 speed. Any and all modes.
Old Jul 12, 2020 | 10:49 PM
blizzard12's Avatar
2017 Mercedes-Benz C300, 2017 Mercedes-Benz GLC300
I have driven 15+ of the W205, different years from 2015 to 2020. All the ones with 7G transmission (7 speed auto transmissions) started in 1st gear. The ones built from 2018 on were all 9G (9 speed transmissions) and those started in 2nd in comfort mode.
Again, the W205 7G starts in 1st gear.
Old Jul 14, 2020 | 04:11 PM
JcE's Avatar
JcE
2017 W205
I’m also having this exact same issue on my 17 w205. It’s weird for sure and I’ve also tried resetting but it didn’t seem to do anything. I’m planning on leaving it alone. Hopefully it doesn’t cause any long term damage or anything.
Old Jul 14, 2020 | 04:59 PM
SnowBenz89's Avatar
Mercedes-Benz C300 4matic
I'm so happy to see a thread about this! (Although I do not have a solution.)
I have a 2016 C300 4matic and it does the same exact thing. Under light acceleration, it holds first gear for a pretty long time, but under moderate acceleration, it shifts "normally." Seems a little backwards to me...
At first, it seemed annoying, but I just learned to live with it over time. Thankfully, it shifts through gears 2-7 shift beautifully, so it doesn't really bother me anymore. I also like how the transmission will only go into 1st gear from a dead stop, so this isn't an issue a majority of the time, or when doing rolling stops at stop signs.
Old Jul 14, 2020 | 05:44 PM
  #32
tyabnet's Avatar
2000 C230 - 2001 E430 - 2003 E320 -
And while you all are playing around and having fun with those shifts and hard acceleration enjoyment - don't forget to give that 722.9 some love with a trans drain refill of the proper fluid.
Old Jul 15, 2020 | 10:13 PM
  #33
GreekUPS's Avatar
‘15 C300 4M Sport, ‘20 GLC300
Same here, ‘15 with 7 speed.
Old Jul 16, 2020 | 09:43 AM
  #34
GJC400's Avatar
C400
Just to clarify... from my brief research, 4 cylinder w205's with the 7 speed start in 1st gear. 6 and 8 cylinder w205's start in 2nd gear. If a 4 cylinder w205 with a 7sp is starting in 2nd, maybe at some point the 7G transmission software was updated with the incorrect option, the trans could have the wrong amount of fluid in it, or maybe there's an electrical or mechanical issue with the transmission. I'd recommend taking it to a mechanic that specializes in Mercedes Benz vehicles.
