Stop Vehicle, Shift to P, Leave Engine Running
Old Aug 5, 2020 | 12:42 PM
JAMADOR's Avatar
2015 C300 Sport
Message has popped up on the dash display.
Can starts & runs fine. Hooking up to a charger on the main battery has no effect.
Have read it may be the aux battery/voltage reducer. Is this the likely culprit? Definitely a lot cheaper to replace than the main battery or alternator.
Old Aug 5, 2020 | 07:25 PM
pussgalore's Avatar
na
Unhappy
I've got the same issue for over a year now. My battery seems to be healthy. The thing is that my car has dashcams even when it's parked and I don't drive this car much.
There are lots of threads on this topic online and some say replacing aux battery/capacitor fixed theirs. I tried aux battery replacement but didn't work for me. Maybe the part I got was a defect... or another possibility is that the front SAM module is acting up.
Old Aug 6, 2020 | 05:57 AM
Doa's Avatar
Doa
W205
i had this the last 12 months a few times. Every time when my car stood too long in the sun or i drove more then 300km in 1 time.
put my car at the dealer last month and 1 of the cells from the main battery was damaged so they replaced my battery
sad part is now my start stop function works again every time :/
Old Jun 5, 2023 | 01:19 PM
luffy09876's Avatar
mercedez
I apologize for bringing up this old thread. I had a similar issue with my vehicle recently; it turns out that I had a discharged battery which is a common cause for this issue. Then you can jump to the conclusion that you had a defective voltage regulator on your alternator w\that is responsible for charging your car’s battery. I did a lot of searches on this issue and came across an in-depth article that may be worth reading. Search for "Mercedes-Benz Stop Vehicle Leave Engine Running on YOUCANIC" and you will see an article that goes over common causes and possible fixes. You can read about it yourself. I hope this information can assist someone else with a similar issue.
Old Jun 5, 2023 | 06:31 PM
Doug129's Avatar
Mercedes SL320
Same issue just yesterday, battery check showed it was tired and not holding a full charge, new battery, message gone, all good.
